Old 22nd May 2009, 23:38   #16
d3mon's Avatar
Thanked: 622 Times
Originally Posted by drvarunagarwal View Post
The dealer there said that there is no need to install one due the same reasons as mentioned in your respective posts. He said (and the car's manual confirms it) that there is a transponder chip placed in the key which wirelessly communicates with the engine and if the original key is not there inside the car the car will not start.
Well that part is definitely true. The engine will simply refuse to start until the key has been authenticated. Duplicating the key will be of no use to a thief
Many car companies are offering this these days, Maruti has it's iCATS system on all new cars now. Don't know about others.
d3mon is offline   Reply With Quote
Old 23rd May 2009, 00:11   #17
Tata Vista has RFID immobilizer in the key.
janitha is offline   Reply With Quote
Old 23rd May 2009, 18:36   #18
Thanked: 103,470 Times
Cars are getting stolen (including icats enabled Maruti's or similarly equipped Scorpios) despite having this anti-theft feature. No car is theft-proof. That's why I posted earlier that the key is to make things as difficult as possible. A gear lock, irrespective of whether the car has icats or not, will make the steal less desirable to the thief.
Old 23rd May 2009, 21:30   #19
If the thief can't start the car only how does having gear lock be of additional help?
drvarunagarwal is offline   Reply With Quote
Old 23rd May 2009, 21:31   #20
k2max6's Avatar
Thanked: 130 Times
How effective are gear locks ?? the ones in which the rod goes in...
I have heard all these encryptions and RFID works only when someone uses a key to steal...but what if the thief bypasses the lock by just opening the under steering cover...
And how about MICRO VBB ??? is it helpful??
k2max6 is offline   Reply With Quote
Old 24th May 2009, 09:05   #21
ImmortalZ's Avatar
Thanked: 312 Times
Accessing the starter wires isn't going to help much when the ECU won't turn on the fuel pump, refuses to run the injectors and shuts down spark. The pleasures of owning a Civic.
Old 25th May 2009, 22:28   #22
The same with my i20 (I guess, cany any expert confirm?). That is where the question arises, how gear lock is of additional help if any?
Old 26th May 2009, 11:07   #23
You can count on Indian ingenuity to find a solution. Theives now roam around with cracked ECUs! Refer to this thread (Is iCATS really tamper proof?) for more information.
There isn't a system out there that is 100% theft-proof.
Old 26th May 2009, 11:19   #24
rkbharat's Avatar
Thanked: 613 Times
are those chipped keys, like one I have for SX4 , are of any use? Does that gives some protection to handover the key to washer guy? Because I think duplicating the key is easy but it will not be easy and quick to duplicate the chip in side the key base.
Though as base rule, I never handover the key to washer or parking attendant, even if I have to move to another parking.
rkbharat is offline   Reply With Quote
Old 26th May 2009, 11:20   #25
prince_pervez's Avatar
Thanked: 34 Times
Best (and convenient) ways to protect your car against theft in India:
1. Use a solid gear lock (the type that permanently bolts on to your car). Second option is a steering lock.
2. Security alarm + motion + impact sensors + immobilizer.
I have a gear lock and a steering lock and Autocop.
The point is, even if a thief is determined enough to cut through the
steering lock and uninstall the gear lock, he will have to have a good amount of time to do the deed, which in many cases is not feasible.
5. Don't let your car keys circulate amongst the watchmen / car wash guys of your society.
Good point and severely neglected!
Of course, no car is theft-proof and a determined thief will still be able to drive away with your wheels. But the key is to make it as difficult as possible.
prince_pervez is offline   Reply With Quote
ARTICLE: Guidelines & Tips for Safe NIGHT Driving GTO Drive Safe 122 26th September 2017 04:54
SUV safe driving tips anybody? freewheelburnin Technical Stuff 26 31st March 2013 21:11
A few useful tips on Safe Off-Roading DKG 4x4 Technical 27 9th October 2009 21:42
To keep or not to keep...am confused lohithrao Sedans 13 9th April 2008 10:48
