Old 20th May 2009, 19:29   #16
ImmortalZ's Avatar
Thanked: 312 Times
Use your power brakes.
Hold down the brakes, blip the engine. You'll feel the pedal going lower. This is the vacuum assist doing its thing. Do this a couple times and you'll have maximum pressure on the brakes (which you will need with all that 3.5 V6 torque dumped on the wheels before launch). Then, rev it to a good range and let go of the brakes when the lights go green.
Remember, do not keep the revs and the brakes on for a long time. You'll cook your A/T fluid and damage the torque converter. This is why racing cars with automatics have a separate transmission fluid cooler.
Old 20th May 2009, 19:40   #17
If you havent had much practice with the brake-rev method, I suggest you do the usual flooring of the accelerator. The brake-rev method is easy to mess up for beginners but is undoubtedly more useful if done right. So either practice that or use the easy way. Hope that helps.
f450 is offline   Reply With Quote
TVS to launch Automatic Motorcycles & Scooters in 2013 GTO Motorbikes 25 11th July 2017 08:54
Buying an Automatic Car (Preferably Diesel). EDIT : Bought an OHC Automatic! Games Goblin Modifications & Accessories 27 13th October 2011 11:09
Another automatic in the house - i10 Automatic jesal Test-Drives & Initial Ownership Reports 167 12th August 2011 12:59
The Perfect Launch During a Drag Race normally_crazy Technical Stuff 34 3rd March 2008 04:01
WagonR (automatic) or Santro (automatic) Blue Thunder Hatchbacks 6 24th August 2007 08:39
