Old 25th May 2009, 10:11   #16
laluks's Avatar
Thanked: 9,725 Times
Originally Posted by kiranpashtakar View Post
Guys
I am sure MASS will suggest a replacement of the fuel tank.
or better still replace the car
I guess MASS would be happy with replacing fuel tank, Skoda would be happy replacing the car
BTW, Will this cause any serious issues anywhere? I am also curious to know.
laluks is offline   Reply With Quote
Old 25th May 2009, 10:35   #17
varun911's Avatar
Is it just the needle or with the syringe? You could have injected using only the syringe, why the needle? ?
If the syringe went in, my guesses are it should float.
varun911 is offline   Reply With Quote
Old 25th May 2009, 10:37   #18
Just the needle with the holder went in, The syringe was in my Hands. (so much for safe hands)
kiranpashtakar is offline   Reply With Quote
Old 25th May 2009, 10:54   #19
breezydrive's Avatar
Thanked: 75 Times
Try this, seriously!
Ask your mechanic to do a jugaad of fitting a magnetic strip externally on the bottom of fuel tank Or else buy few small magnets & stick them on the bottom of fuel tank with ELFY/ Araldite. Needle with get struck on the bottom of Tank due to magnetic effect.
Cons: Ferrous metals from the road surface will stick to the tank.
breezydrive is offline   Reply With Quote
Old 25th May 2009, 10:54   #20
tsk1979's Avatar
Thanked: 16,422 Times
Get fuel tank removed.
Remove petrol
Hold upside down, and shake hard till needle comes out.
Old 25th May 2009, 11:06   #21
varun911's Avatar
The needles are usually of stainless steel. So I dont think magnets would help, because, mostly stainless steel are non-magnetic.
Old 25th May 2009, 11:09   #22
teknophobia's Avatar
Thanked: 22 Times
Get oe of those round magnets with a hole in them, tie a piece of string to it and fish the needle out of the tank.
teknophobia is offline   Reply With Quote
Old 25th May 2009, 11:33   #23
sgiitk's Avatar
Thanked: 3,884 Times
I think every modern car has a fuel filter on the fuel line so just forget it.
sgiitk is online now   Reply With Quote
Old 25th May 2009, 13:47   #24
SS-Traveller's Avatar
Thanked: 11,630 Times
...I was hoping the experts on the forum will guide me on if there is a fuel filter in a baleno...
Why do you think the experts are poking fun at you? Nothing will ever happen to your Baleno if you let the needle take up permanent residence inside your petrol tank. The fuel pump has a filter at the tank end, there's a fine fabric filter at the engine end of the fuel line, then there is a filter where the fuel line feeds the injection pump. Not even a grain of sand gets through. Your needle will need to fragment itself into molecular bits to go into your engine and cause any damage.
So forget the needle and enjoy the drive (unless you are very emotionally attached to that needle and hate to see it die of drowning in petrol ).
Old 25th May 2009, 13:58   #25
Hey thanks SS, that's exactly what I wanted to hear.
Baleno has some self protective shield after all.
Petrol Tank Modification ( Petrol Leak ) thimappa Motorbikes 1 18th May 2009 12:04
Swift Zxi - RPM needle suddenly jumps to 4K rajatmakar Technical Stuff 7 15th July 2008 13:59
Tachometer Needle Vibrates at High Revs - Help amannarwal Technical Stuff 17 28th March 2008 11:02
Fuel guage needle going up and down manikjeet Technical Stuff 8 14th March 2007 15:37
my speedo ended !!!- zen needle crosses last point on speedo speed0mania Street Experiences 81 11th August 2006 12:22
