Old 25th May 2009, 22:19   #1
akshay_b's Avatar
Unhappy Audio system/roof light/door warning-Gone kaput together.
Hello guys,
This is quite a weird scenario, I turned the roof light switch on, the light came on and the switch broke there was no way to turn it off so I decided to pull out the bulb out of the socket so that it shouldn't hinder my night driving and all of a sudden my head unit refused to turn on and when i press the lock button on the key less entry remote,the siren beeps for some time and locks, this tells me a door might be open,
There's no door ajar warning light on the instrument cluster , I checked all 5 doors + the hood door. All door seems to be properly shut, All electrical stuff are working fine. Could it be a blown fuse? Should i check for anything before taking it to the service station?Please help,
P.S- I own a Santro xing.
akshay_b is offline   Reply With Quote
Old 25th May 2009, 22:21   #2
greenhorn's Avatar
Thanked: 1,518 Times
sounds like it. is there some way you can open up the fuse box and examine it yourself ?
There are Two Fuse Boxes in the vehicle
- Engine compartment Fuse Box (ECFB)
- Passenger Compartment fuse Box (PCFB)
The latter should what you need to check. it should be under the front right speaker grill. If the fuse blows again, you might have shorted something in the electricals , and have to get it checked by the service center
Old 25th May 2009, 22:26   #3
Thanked: 167 Times
Try fixing the bulb back in the roof light. If it does not work then it should definitely be a blown fuse.
malgudi is offline   Reply With Quote
Old 25th May 2009, 22:29   #4
akshay_b's Avatar
I wasn't aware of the PCFB, Will check in the morning.! Thanks
Tried- The bulb doesn't turn on. Sure its a blown fuse?
Old 25th May 2009, 22:58   #5
srikant's Avatar
Thanked: 9 Times
It must be a blown fuse. But i am hearing of such an incident for the first time. Take it to the service center. Should not be a major problem. Do keep us updated. I m curious.
srikant is offline   Reply With Quote
Old 26th May 2009, 04:18   #6
SLK
SLK's Avatar
Thanked: 192 Times
Funny!, Sounds like a short circut while taking the bulb out, fine the audio system doesn't work, BUT the central locking is reacting exactly opposite! It reacts this way when the 'roof light' is on due to door open.
That would mean the central locking is reading the light as ON. Well, could be a fuse, or/and could be some kind of persistent circuit due to the broken switch.
SLK is offline   Reply With Quote
Old 26th May 2009, 12:25   #7
akshay_b's Avatar
The roof light switch is so delicate that it breaks twice in a month , This is the first time its happening though :(
Old 26th May 2009, 13:00   #8
benbsb29's Avatar
Thanked: 4,281 Times
Definitely a case of your fuse getting blown. I managed to blow the fuse in my car during my DIY experiments with LEDs and the cabin light, backlit lighting for power window controls etc stopped working. Replaced the fuse, and the world was back to normal.
Old 26th May 2009, 15:43   #9
akshay_b's Avatar
Guys, Just fixed it, It was the "ROOM LP/AUDIO" fuse blown out
Thanks everyone (The head unit reverted back to factory settings , its a pain now to set back to what it was, The EQ, Time,the radio stations and stuff)
Old 26th May 2009, 16:02   #10
ASHISHPALLOD's Avatar
Thanked: 286 Times
man,
good to know that everything is normal now,
you should be happy about that pain as it is without any cost.
if anything major fault happened, think about that pain.
ASHISHPALLOD is offline   Reply With Quote
Old 28th May 2009, 12:58   #11
mithun's Avatar
Thanked: 59 Times
Is this available in all cars or is it limited to Santro Xing ?
Old 28th May 2009, 13:23   #12
SLK
SLK's Avatar
Thanked: 192 Times
All. Its normally behind the Bonnet open lever.
Old 15th July 2009, 21:09   #13
srikant's Avatar
Thanked: 9 Times
can anybody help me find the spare fuse placement in swift DDiS? and also the clip to remove and replace the blown fuse in fuse box?
Old 15th July 2009, 22:18   #14
ghpk's Avatar
Thanked: 193 Times
Spare Fuses are usually in the LID of the FUSE BOX, Or you can see it your fuse Box Label Displays Icons for Spare fuse along the ones which are used.
Old 16th July 2009, 10:44   #15
gpa
gpa's Avatar
Thanked: 282 Times
I'm keeping a keen eye to see what the outcome is. I've never faced such a problem in my Xing, even though I've removed the bulb when it was switched on.
Installing roof racks without factory roof railings hellmet Technical Stuff 13 8th March 2013 10:49
Skoda Octavia RS 1.8 TPi Gearbox gone kaput @ 60,000 Kms!! nanu28 Technical Stuff 34 22nd March 2011 12:08
Alto clutch gone kaput @ 13000 km / 1 year burnt. Technical Stuff 11 9th December 2010 22:57
Palio 1.6 ac compressor gone kaput kapilsharma80 Technical Stuff 3 3rd July 2009 16:33
Is my headlight relay gone Kaput? WAGON_R Technical Stuff 9 3rd March 2009 11:36
