Old 29th May 2009, 08:29   #1
Surprise's Avatar
Thanked: 272 Times
Default Strange sounds at high speeds
In a recent highway trip have come across a strange sound "krrkkk" in my Swift, whenever I encounter road surface levels with a very minute difference. This surface level differences will be obvious when you hit the newly paved roads as the level of the new road will be 1/2 inch higher. Not sure whether this comes from the front or rear of the car, but surfaces only at speeds over 80 kmph. Couple of times, this noise has even come, when I press the brake pedal softly. In a 1500+ kms trip have come across such noises about half a dozen times, hence this problem comes intermediately
Took it a nearby service station & was told that probably this sound is from front suspension. He added that due to regular city drives the suspension set up would have been limited to certain play, when these were tested at high speeds after a longer duration, such sound will come for first few times. There is no any direct answer for similar sounds when brake pedal is pressed (but this has come only for couple of times)
When you hit such level difference at high speeds (100-110 kmph) the noise is higher & once when I hit the brake (softly) at 100 kmph was really scared on the noise for the first time
Anyone else faced a similar problem?
Surprise is offline   Reply With Quote
AC Woes, and strange sounds tsk1979 Technical Stuff 31 8th July 2008 15:22
Strange sounds from the Caliber console abdriver2000 Motorbikes 1 8th February 2007 11:41
Periodic noise at high speeds (Innova) oldmobile Street Experiences 0 11th September 2006 15:53
No power assistance from EPS at high speeds - Why ? mithun Technical Stuff 15 25th August 2006 23:00
Which is better ?AC ON or Windows rolled down in high speeds prince1a Technical Stuff 19 18th June 2006 11:54
