Old 2nd June 2009, 18:49   #16
trrk's Avatar
Thanked: 13 Times
Hi Joe,
The problem in your case is that we still don't know which ahs gone bad?
Though the brake booster can go bad, it would be a rare occurrence. I tend to agree with the mechanics version.
Did you try all those tests suggested here and in the Yahoo group posts?
Testing for the booster is easy as mentioned in one of the earlier posts.
trrk is offline   Reply With Quote
Old 2nd June 2009, 21:05   #17
yzfrj's Avatar
Thanked: 119 Times
@joecherian
I'd really advice to get it checked someplace else yar.
You see if brake fluid is indeed leaking (inside the booster) as trrk said, oil levels will go down. Again once oil is inside there is nothing much you can do.
It has a rubber diaphragm, once brake fluid touched rubber you know what will happen. I really don't think a master cylinder failure (oil seal or whatever) will leak oil into the booster. I did replace the entire oil seal "O"-ring kit once it did not spoil the booster.
Let us know once you check her out elsewhere.
I think that is the best way forward as the local guy and Authorized guy seems keen in taking you for a expensive ride.
yzfrj is offline   Reply With Quote
Old 8th June 2009, 06:56   #18
joecherian's Avatar
Thanked: 78 Times
The update is, I went to Manipal motors, have them check the brake and then they too came to the conclusion that the booster assembly has to be replaced.
My question is, how much do they charge as labor charge for this job ie, brake booster assembly replacement ? Prerana motors quoted 900 and told this is around 3-4 hours job. A local work shop mechanic told this is a 1 hr job. Since this is a critical component, I am not sure whether I should go with the TASC or a local mechanic and more over, is the labor charge of 900 justifiable ?
I have bought the booster assembly outside and now need only the replacement job done.
joecherian is offline   Reply With Quote
Old 8th June 2009, 08:28   #19
rkbharat's Avatar
Thanked: 613 Times
900 Rs is ok, get it done at TASC, if they are ok with working on parts bought by you. Removing and fitting booster is very time consuming job if not very technical. Space in Indica and Indigo around booster is very less, so alot of parts have to opened up to get it on place
rkbharat is offline   Reply With Quote
Old 8th June 2009, 12:52   #20
trrk's Avatar
Thanked: 13 Times
Hi Joe,
After the work is over and you are free of this problem, please do give us the details including price of the booster that you bought.
Thanks.
Old 9th June 2009, 07:58   #21
joecherian's Avatar
Thanked: 78 Times
Originally Posted by trrk View Post
Hi Joe,
Thanks.
The latest update is , my brakes are back to normal. Went to Prerana on OMR, had them change the booster. It was bit tough for them to get the booster out from its seating as there were too many obstructions. Finally, then got it out. I knew this and hence I was near the car when the whole work was done so that they don't do any mess up..
At th end, the total cost came up some thing like
booster : 5200 ( Tata price is 6600)
labor : 550
On a side note, would like to know whether any of the BHPians had given their Indigo with reg no KA ** M* 6714 for service in Prerana Motors OMR yesterday ? Since I was inside the work area seeing the work being done on my car, saw a large group assembling behind this Indigo and there were lot of talks in between them.. It seems, one of the mechanics, while backing out the car, rammed it against some vehicle or wall and the result is rear right tail lamp is shattered completely and the rear right portion of bumper also got some damage. I am not sure whether this happened inside the work shop, but the body language of the workers there seemed fishy.if it belongs to some one known to you and if the workshop keeps this unknown to the owner, do pass this info..
Old 9th June 2009, 13:05   #22
trrk's Avatar
Thanked: 13 Times
Hi Joe,
labor : 550
Thanks for the update.
Evidently the booster change did cure the problems.
Some seal must have given way for oil to go into the booster. I am surprised that it was beyond repair.
Old 9th June 2009, 14:27   #23
joecherian's Avatar
Thanked: 78 Times
Hi Joe,
It could have been repaired (atleast as per the local mechanic whom i consulted , not sure about the authenticity of his claim, but he told he has done this stuff). But, since it was a brake system, I didn't want to take any chances.. Just to have a peace of mind while driving.
My BRUTE-FORT: Toyota Fortuner 4x4 M/T [Upgraded Brake Booster & A/T Tyres] EDIT: Now sold! karan561 Long-Term Ownership Reviews 232 14th December 2017 23:20
Booster Brake Adjustment - Is it possible? mail4ajo Technical Stuff 31 30th September 2015 21:31
Swift Diesel - New Brake Booster Design By Maruti humyum Technical Stuff 181 23rd May 2013 17:12
Brake Booster Failure on a New Ford Fiesta 1.6S. Need help/info! capt_rocker Technical Stuff 37 1st November 2011 17:39
Improving Zen MPFI brakes by fitting an Esteem Type II brake booster etc Trust_In_Thrust Modifications & Accessories 26 6th June 2010 12:42
