Old 31st May 2009, 00:03   #1
joecherian's Avatar
Thanked: 78 Times
Default Brake booster Assembly of the Indigo
My 6 yr old Indigo needs to go for a change to her brake booster assembly. Prerana Motors is asking 8000 bucks for the same. I would like to know whether I can get the same outside ? Does any one know some shops in Bangalore where in I can get the same ? OR is it better to go with the quote given by Prerana ?
For Indigo, which brand of brake booster is the best in terms of reliability ?
joecherian is offline   Reply With Quote
Old 31st May 2009, 14:54   #2
trrk's Avatar
Thanked: 13 Times
Hi Joe,
This is what I got from Justdial search:
Brakes India Ltd
Mr Mohan Raj
+(91)-(80)-23336211, 26494436
No.8, 80ft Rd,hmt Lyt, R T Nagar, Bangalore - 560032
See if this helps. A post in another thread suggests this manufacturer.
trrk is offline   Reply With Quote
Old 31st May 2009, 15:48   #3
rkbharat's Avatar
Thanked: 613 Times
AFAIK Tata cars comes with two brands of booster KBX and I think TVS. I once changed the brake booster of my Indica from outside. Bought it from spare shop for 2500 Rs and labor 900 Rs.
8000 is too high, unless there is some thing great in those boosters.
I suggest procure it from local spare shop. Check the brand currently fitted.
Any good Tata Mechanic will fit it.
rkbharat is offline   Reply With Quote
Old 31st May 2009, 20:24   #4
trrk's Avatar
Thanked: 13 Times
If it is KBX, then the following could be useful. Got from the same source.
Kalyani Brakes Ltd
Mr Nibulkar
+(91)-(80)-22120309
Lalbagh Rd, Bangalore - 560027
I hope these entries are correct!
Anyway this is what I have:
It is a TVS one.
Old 31st May 2009, 21:22   #5
SLK
SLK's Avatar
Thanked: 192 Times
Slightly off topic, but would like to know:-
What are the symptopms that suggest that the booster is bad?
Isn't it just a thing which will either perfectly work or completely fail? - how are you still driving?
SLK is offline   Reply With Quote
Old 31st May 2009, 21:36   #6
yzfrj's Avatar
Thanked: 119 Times
Well for starters, you'll feel the brake to be spongy and braking distances will be more.
Simple way to check if the booster thingy is doing its stuff :
-Press down the brake pedal with the engine off.
-Start the engine with you foot on the brake.
-You should feel the pedal pushing (very mild)
If it remains as is, chances are the brake (not necessarily the booster) is having some problem.
Well I've had 2 booster failures, one on my bro's wagon r and one on my zen.
I was driving the zen without the booster for more than a year.
As per the service guys it was not "fully" gone.
But yes the brakes were spongy and the pedal was lifeless.
Bottom line it was a failure, but not a failure that made the car/brake dangerous (well yes the brakes were bad compared to the original) but its still drivable and will not stop the show.
However in my bro's wagon r, it was more "drastic" oil was leaking into the booster assembly (I had to top-up every 200-300kms). In this case immediate replacement was the only solution.
Zen it came around 4k, wagon r it was around 5k.
yzfrj is offline   Reply With Quote
Old 31st May 2009, 21:57   #7
Awaiting Email Confirmation
Thanked: 319 Times
Default Whats the readon for changing the whole assembly.
The only part that can go easily is the bellow. I suggest you change just this part.
Bye and wear your seat belts.
drpullockaran is offline   Reply With Quote
Old 31st May 2009, 23:51   #8
Thanked: 660 Times
Booster can't be repaired. Its a sealed unit and there is a reason for keeping it that way. But the good thing is its failure rate is low.
Whay did you came to the conclusion that its faulty.
Old 1st June 2009, 08:07   #9
joecherian's Avatar
Thanked: 78 Times
Originally Posted by trrk View Post
Hi Joe,
Brakes India Ltd
Mr Mohan Raj
Thanks trrk. I tried the number but it seems they have shifted the office from this location. Trying to contact Madras Auto service as they are the distributors for TVS break boosters
Kalyani Brakes Ltd
Mr Nibulkar
+(91)-(80)-22120309
It is a TVS one.
I will contact them too to see whether they have the Brakes India brake boosters as the TATA uses them from Brakes India ( which I guess is a TVS group company)
yes, even I felt it same. 8000 seems to be th every high extreme and hence trying to figure out alternate sources.
Well, I felt like braking is less effective, more over, the pedal goes way down . These were the initial symptoms and then I took my car to Prerana where they diagnosed that oil was going inside the booster assembly and hence proper vaccum was not getting created. It seems Indigo ( mine is the first batch) has hydraulic assisted vaccum brakes (?).
Mine is the same case. Oil is going inside the booster assembly( as per the service technician)
Old 1st June 2009, 09:18   #10
ilangop's Avatar
Thanked: 591 Times
Oil leaking into the vaccum booster could be due to worn out Master cylinder seals. You may either replace with a new MC kit or replace the master cylinder itself. Have you tried out the pedal travel test for the booster, as mentioned in one of the previous posts.
ilangop is offline   Reply With Quote
Old 1st June 2009, 09:27   #11
joecherian's Avatar
Thanked: 78 Times
Well, I haven't tried the pedal test , but as per the service advisor who inspected my vehicle, they told that the booster assembly has to be replaced. I am not sure whether they wanted me to buy the unit as a whole ( to make some bucks) instead of replacing the master cylinder.
Can the MC be replaced on its own or is it part of some larger component which has to be replaced as a whole ?
On a different note, does anyone has any contacts in Madras Auto Service ? I called their bangalore office for getting the booster assembly , but, it seems they won't sell it to individual customers and only to dealers. Hence, looking for some contacts who can help me get the same from Madras Auto Service.
Old 1st June 2009, 09:29   #12
joecherian's Avatar
Thanked: 78 Times
Can anyone provide me the part number for brake booster assembly for KBX as well as Brakes India ?
Old 1st June 2009, 14:05   #13
trrk's Avatar
Thanked: 13 Times
Sorry about that. Can't find anything on the online BSNL directory either!
No way. This is is a different company and they won't be able to give you a TVS product. I mentioned it here only because rkbharat mentioned this as another OEM.
I can't comment on the technical aspects of the problem, but be reassured that every Indica / Indigo and its cousins have the same arrangement.
In a diesel car, this vacuum is created by a pump which is fitted behind the alternator.
They should find out why the oil leaks into the booster. Does your brake fluid gets empty?
Sorry can't be of much direct help here. Also if you go by their diagnosis and rectification, ensure that the problem gets rectified to your satisfaction before you pay up.
Just take a look at the following:
Yahoo! Groups
Old 1st June 2009, 20:49   #14
joecherian's Avatar
Thanked: 78 Times
Today, I went to a local mechanic for double checking my brake issue and the mechanic had a different version. His findings are that the master cylinder has to be replaced and not the booster assembly.Now, I am having double thought regarding the same as to why did Prerana ask me to replace the entire brake booster assembly.Anyways, I am planning to take the vehicle to another TASC to get their diagnosis..
Old 2nd June 2009, 09:08   #15
joecherian's Avatar
Thanked: 78 Times
I don't want to compromise on safety and hence am thinking of replacing the entire brake booster assembly. Hence, would like to know whether this indeed is the right step or should I go ahead and replace just the master cylinder ?
My BRUTE-FORT: Toyota Fortuner 4x4 M/T [Upgraded Brake Booster & A/T Tyres] EDIT: Now sold! karan561 Long-Term Ownership Reviews 232 14th December 2017 23:20
Booster Brake Adjustment - Is it possible? mail4ajo Technical Stuff 31 30th September 2015 21:31
Swift Diesel - New Brake Booster Design By Maruti humyum Technical Stuff 181 23rd May 2013 17:12
Brake Booster Failure on a New Ford Fiesta 1.6S. Need help/info! capt_rocker Technical Stuff 37 1st November 2011 17:39
Improving Zen MPFI brakes by fitting an Esteem Type II brake booster etc Trust_In_Thrust Modifications & Accessories 26 6th June 2010 12:42
