Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 1st June 2009, 16:37   #1 (permalink)
yzfrj's Avatar
Default Swift - Scratched Brake Disk, Help...!
Guys Need help/advice
2008 July Swift VDi
15000+ Kms
Problem : Scratch on front right brake disk.
This was noticed after the 3rd service @10k Kms, I'd say we noticed it around 11.5k. Car is being serviced @ Popular (Elamakkara, Cochin)
This is my dad's car.
He has taken up with the service center people.
Explanation was funny IMO.
They said - It might be due to a piece of metal wedged between the brake pad and the disk.
My dad is a very good driver and always takes care of the car.
Particularly he hates any sort of "unwanted" noises, takes care of the right away. So metal wedged would IMO should make a lot of noise (similar to worn out pads).
Anyway it was told by the service center people that it will be resolved in the next service. 15K kms service is over now. They said they need to write to Maruti to get a "solution".
According to them its 900/- for the disk.
Apart from the scratch mark there is no noise or any other "problem" with braking. Its awesome as ever.
My worry is what is the root cause of the problem ?
I'm not happy with the service center guys explanation.
Its a steel disk and I seriously doubt a metal piece can do this.
They (Maruti) might even replace the disk.
2 weeks time was requested. so they have a few more days left.
I've never seen this so guys need your expert comments/ suggestions.
Pics are of low quality it was taken by the service guys and was sent to Maruti.
yzfrj is offline   Reply With Quote
Old 1st June 2009, 16:52   #2 (permalink)
sgiitk's Avatar
Every brake disc gets scored with use. The mark you have pictured appears to be quite normal and I will not worry.
__________________
Life is short, do not make it shorter!
Accent GLS 2002
Santro Automatic 2005
Old 1st June 2009, 17:07   #3 (permalink)
yzfrj's Avatar
Agreed. My Zen which is 91k Kms does have scratches. However it does't have a single scratch (which is say more than 1mm deep).
This is a relatively "new" car and the depth of the scratch is a bit more than 2mm, that too happened sometime between 10k service and 11.5k (when we spotted it).
Is't it too early and the car has clocked too little kms for this ?
Old 1st June 2009, 17:40   #4 (permalink)
sgiitk's Avatar
The depth does not appear to me 2mm in the pictures, the width does. But then pictures can be deceptive. Most likely you had some hard grit between the pads and the platter which did the damage.
If you can get them to replace it foc then it is fine. However, It will be very difficult to establish that it was a manufacturing defect. I also cannot imagine as to how and why can the A.S.S. do it!
However, at the time of disc pad change, you may have to replace the disc platter. I do not think cutting off 2mm from a face is permissible, esp. with ventilated discs.
__________________
Accent GLS 2002
Old 1st June 2009, 17:44   #5 (permalink)
vikram_d's Avatar
There is nothing to be worried about. I would advise you to leave the disc as it is and continue using it. Just get the brake pads replaced if needed.
__________________
Been there. Done that.
Old 1st June 2009, 17:50   #6 (permalink)
yzfrj's Avatar
@ sgiitk - Yes I think you are right 2mm depth seems a bit much for me too.
I'm wondering if this happened due to improper assembly of the brake pad thingy after the 10k service.
@vikram_d - not sure if pads were replaced already. will check on that.
Old 2nd June 2009, 02:14   #7 (permalink)
SirAlec's Avatar
IMO the pad that came with your car was faulty, or had some manufacturing defects. Its not a steel disc.
Its not a problem, if you don't feel any wobble at high speed. just keep it with new set of pads.
__________________
Still! Living Life a quarter mile at a time.....post being Dad.
Old 2nd June 2009, 19:55   #8 (permalink)
yzfrj's Avatar
Cool These guys really do care about the customer.
Update :
Dad got a call from Popular Service that a guy from Maruti would like to meet him and discuss the issue. My dad said he can meet the guy and offered he will come to the service center.
Popular guys told, this Maruti guy - Territory Service Manager(TSM) will come and meet the customer, so dad fixed up time 17:30 location : Home.
Mr. Balaji (TSM) came right on time.
Looked around the car, then came in.
Asked about the service, the issue at hand and said the same thing service guys said and assured this will not be a problem. Dad was not convinced and said he'd rather have it replaced.
Mr. Balaji said no problem and put a comment requesting Popular to replace the part as soon as possible based on part availability.
He apologized on Maruti's behalf and gave a glass bowel set as a "gift" on Maruti Suzuki's behalf.
Well what more can I say.
Popular service and Maruti Suzuki please take a deep bow.
My car is a Maruti and next car would be a Maruti. Amen.
Old 2nd June 2009, 22:46   #9 (permalink)
motionfreak's Avatar
GR8 gresture by Maruti !!
SKODA are u listening???
motionfreak is offline   Reply With Quote
Old 2nd June 2009, 23:39   #10 (permalink)
srikant's Avatar
Thats a real quick response. Did you have to mail any complaint to get this noticed?
__________________
2001-Hyundai Santro 80k KMS
2005-Hyundai Accent CRDI 75K KMS
2007-Maruti Swift VDi 57k KMS
Swift VDI CARBON
srikant is offline   Reply With Quote
Old 2nd June 2009, 23:53   #11 (permalink)
nitrous's Avatar
Skim the disk if you want to remove the scoring.
If rotor thickness is lesser than minimum, then replace it, worst case.
Maruti sending customer service rep. home and giving glass bowls for such a simple problem is just OTT, IMO. (No offence meant, Riju)
__________________
Han:The Red Evo's yours
Sean:What do u mean?
H:U're representing me now...What did U think, I'm gonna let you roll in a hyundai?
Old 3rd June 2009, 02:13   #12 (permalink)
pranavt's Avatar
Bowel set eh?
pranavt is online now   Reply With Quote
Old 3rd June 2009, 02:54   #13 (permalink)
Roy.S's Avatar
Originally Posted by pranavt View Post
Bowel set eh?
The mind boggles!! MUL customer service is giving out unusual stuff these days!
Roy.S is offline   Reply With Quote
Old 3rd June 2009, 10:49   #14 (permalink)
im_srini's Avatar
Thumbs up
I think the said gentleman also visited my home a few weeks ago (again, he was very punctual). In my case, it wasn't any complaint I'd raised, he came to collect feedback on my last service & my current service-center (ABT, Saligram). He was also very interested to know if I'd been facing any rattling issues in my cars & mentioned that Maruti has asked its people to check up on rattling issues faced by customers (apparently they'd seen a lot of it on the net) !
Well what more can I say. These guys really do care about the customer.
Popular service and Maruti Suzuki please take a deep bow. My car is a Maruti and next car would be a Maruti. Amen.
Have to agree with you there. For the largest car manufacturer in our country, Maruti need not care so much, but I'm mighty glad they do
im_srini is offline   Reply With Quote
Old 3rd June 2009, 12:47   #15 (permalink)
sgiitk's Avatar
Excellent work MS. Even more important it is from a mass manufacturer and not a high cost limited scope vendor (read Skoda here). Obviously one such experience will get MS at least 5 new customers.
__________________
Accent GLS 2002
Thread Tools
Scratched and dented Swift: Time for repairs Thad E Ginathom Technical Stuff 31 5th October 2008 00:18
Disk Brake problem in Bullet zoom_vroom Motorbikes 3 11th August 2008 21:57
Disk Brake to normal brake change? ramki067 Motorbikes 10 7th August 2008 15:19
SWIFT-VXI brake issue raja748 Technical Stuff 7 25th October 2007 12:14
Swift scratched while parking in Pune...need paint spray abhaybakshi Technical Stuff 19 7th March 2007 15:34
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
