Old 9th June 2005, 11:40   #1
artofzen's Avatar
Thanked: 54 Times
Unhappy Oil Color for Accent CRdi
Guys,
Yesterday when i checked my car's oil,It was black in color.My friend told me that it is usually green and turns black when its time for an oil change.Car has done 22000 k ,had done a service at 18000 in which oil change was done(Since oil change is an obvious task,i dint check up).Is there a problm?What do u guys think?.
@Drifter,@Rjk-What is the normal oil color ?
artofzen is offline   Reply With Quote
Old 9th June 2005, 13:36   #2
Psycho's Avatar
Thanked: 95 Times
Oil color may vary however it is the consistency of the oil that is key. Ususally you change oil and the oil filter in the car every 5000 km.
Ways to make out if the oil has gone bad:
1) The oil is thick and rough in between your fingers when you rub it.
2) The oil stinks when you smell it usually is like a burned smell
3) If it is synthetic oil dont go by the color do the consistency and smell test. Synthetic oil is reccomended for a oil change at 10000 km. If you are moving from non-synthetic to synthetic please use an engine flush before changing the oil.
Old 9th June 2005, 16:33   #3
artofzen's Avatar
Thanked: 54 Times
Thanx for the help Psycho ;-)
Old 9th June 2005, 22:23   #4
drifter's Avatar
Whenever i've seen it....its always blackish in colour...btw hyundai has given 10000km intervals for service. My 40000kms service is overdue.
Drifter
drifter is offline   Reply With Quote
Old 9th June 2005, 22:31   #5
Mpower's Avatar
Thanked: 1,687 Times
In a diesel engine, oil turns black right away and its normal.
In a petrol, it should be light brown and translucent. Black is not good.
Old 9th June 2005, 22:56   #6
V-16's Avatar
Thanked: 862 Times
Guess thats why diesels are called oil burners
V-16 is offline   Reply With Quote
engine and trasmission oil for Accent CRDi viva! rider60 Technical Stuff 2 26th February 2008 04:34
Accent CRDi or Accent Viva CRDi Looks abhibh The Indian Car Scene 4 8th November 2005 17:43
Accent CRDi or Accent Viva CRDi abhibh Sedans 16 8th November 2005 05:58
