Old 2nd June 2009, 10:20   #16
Thanked: 49 Times
Neat feature - must have been put in place to warn the driver of the possibility of getting a ticket in places where properly working tail lamps are a must.
If only we have similar "fitness" tests for the vehicles on our roads.
CrackedHead is offline   Reply With Quote
Old 2nd June 2009, 11:01   #17
@hillram- thanks for the invite mate,but the car is with me here in sydney.You have an enviable garage.
D.V.R is offline   Reply With Quote
Old 2nd June 2009, 13:02   #18
Samir Taheer's Avatar
Thanked: 123 Times
Originally Posted by Samir Taheer View Post
Hard to tell and best to check with thr owners manual, but it could mean that one of the lights on your car is not working. So check the headlamps, brakelamps, turning indicators etc, to see if they are working. If not check the bulbs.
I said earlier its most likely that one of the bulbs have gone, but this might help
Replace Rear Bulb Warning Light- SOLVED - Toyota Forums :: Toyota Nation
Search thru the site, youre sure to find more help.
Samir Taheer is offline   Reply With Quote
Old 2nd June 2009, 17:06   #19
laluks's Avatar
Thanked: 9,725 Times
That warning lamp is the usual "tail lights out" one. Check you tail lamps.
laluks is offline   Reply With Quote
Old 2nd June 2009, 18:31   #20
@Samir Taheer& laluks- All the tailamps are working except for the rear left license plate light,will replace the bulb over the weekend and see whether the warning goes off or not.
Thanks for the link.
Old 2nd June 2009, 19:01   #21
Thanked: 123 Times
DVR - The link says it might be a problem with the harness. The warning light will most likely be to indicate a bulb has gone, but if there is a wiring problem somewhere it may stay on even though all the bubls are ok. Hope by changing the licence plate bulb the warning lights goes, but i wouldnt have thought those were monitored. If you post the problem on Toyota Nation one of the experts on their should be able to answer your question.
Bike seized as it was modified. What does this mean for the modifiers out there? Rtech The Indian Car Scene 94 20th June 2016 11:17
Does more heavy mean more safe?? DCEite Technical Stuff 83 5th July 2008 14:16
Tyre "Jump Maar Raha Hai"What does it mean humyum Technical Stuff 26 10th November 2006 18:04
Does safety mean anything here DRC Street Experiences 28 25th August 2006 13:42
What does it mean ? Technocrat Super-Cars & Imports in India 18 26th November 2004 18:45
