Old 2nd June 2009, 12:13   #1
Gill's Avatar
Thanked: 12 Times
Default Soda (sodium bicarbonate) Blasting
Hello,
I am searching for information on Soda blasting and it's availability in India,Would be great if Someone can share from where it can be done particularly in North India!
Have a good day!
Gill
Gill is offline   Reply With Quote
Old 2nd August 2011, 18:29   #2
Gill's Avatar
Thanked: 12 Times
Default re: Soda (sodium bicarbonate) Blasting
Bump!
Even in Bangalore will do.need to clean engine parts of motorcycle.
Old 3rd August 2011, 19:03   #3
Rehaan's Avatar
Thanked: 25,038 Times
I've never heard of Sodablasting, so looked it up. Here's a quick description for others who are interested :
Sodablasting is a process where sodium bicarbonate is applied against a surface using compressed air. An early use was to restore the Statue of Liberty in the late 1980s.[1]
Sodablasting is a non-destructive method for many applications in cleaning, paint stripping, automotive restoration, industrial equipment maintenance, rust removal, graffiti removal, molecular steel passivation against rust, oil removal by saponification and translocation, masonry cleaning and restoration, soot remediation, boat hull cleaning and for food processing facilities and equipment.
Source
cya
R
Rehaan is offline   (1) Thanks Reply With Quote
Old 9th July 2014, 17:37   #4
magneto's Avatar
Thanked: 47 Times
Source
cya
R
hi i am going to try and clean some carb parts with a pilot make sand blasting gun using wasing soda ,.
magneto is offline   Reply With Quote
Old 11th July 2014, 14:34   #5
Rehaan's Avatar
Default Re: Soda (sodium bicarbonate) Blasting
Hi Magneto,
Sounds interesting. How about some pictures of the gun, as well as before/after comparo pics of the carb?
cya
R
Old 11th July 2014, 16:13   #6
joybhowmik's Avatar
Thanked: 1,928 Times
Hi Magneto,
cya
R
is the gun available anywhere - even online? I am interested in removing the chrome from my ORVM's because one section is scratched to the underlying plastic. Then, once blasted, planning to have it painted in the body colour. Only if I had a gun then it would have been easy enough to remove the chrome. Depending on abrasive paper won't give as even finish as blasting.
Old 21st July 2014, 13:27   #7
magneto's Avatar
Thanked: 47 Times
Unfortunately i do my work at my farm due to space constraint in Mumbai, so will take pictures next time i go there.
In the meantime you can check out Pilot spray painting guns. The sand blasting gun is made by the same people.
Last edited by Rehaan : 21st July 2014 at 14:10. Reason: Post edited for readability. Please don't use spaces before punctuation marks. Thanks! :)
magneto is offline   (1) Thanks Reply With Quote
Soda Blasting in Bangalore: Strip any coating from any surface GTO Technical Stuff 15 10th June 2015 17:22
Half a litre SODA in fuel tank! dhanushs Technical Stuff 55 15th June 2010 09:19
Advanced and Mind blasting I.C.E for my civic BmwAddict In-Car Entertainment 117 10th June 2009 10:44
Mecury Vs Sodium Headlamps RCS Modifications & Accessories 4 25th February 2008 16:53
Powerful Skoda Or Another Flat Soda? MrBoombastic The Indian Car Scene 40 21st November 2005 00:09
