Old 20th August 2009, 15:25   #31
sathee46's Avatar
Originally Posted by anachronix View Post
I got a complete ECU reset from Ford A.S.S and the problem is history now. I beleive its nothing to do with the starter motor.
+1, I had my GEM module replaced and my ECU reset.
There is one more issue in my car which I want to be clarified here, when I am revving my engine high and shifting gears I hear a 'creak' noise when I slot into 4th Gear. Either way from 3rd to 4th or downshifting from 5th to 4th and I can hear this 'creak' noise. Got it checked twice by the Ford A.S.S and they found nothing to be wrong.
It's something to do with the clutch depression and some minor adjustments there. I had the same issue with my reverse gear, this is what the service advisor told me when I had reported this problem
sathee46 is offline   Reply With Quote
Old 20th August 2009, 16:35   #32
vnabhi's Avatar
Thanked: 1,311 Times
Anachronix---I've never had the click sound while changing gears. As regards system G, i get it from Ford Service Centre---it used to cost Rs 250, but now costs Rs 299 for the past 2 months or so.
Old 20th August 2009, 16:45   #33
sathee46's Avatar
It's not a simple click sound, it's sounds like grinding the gears.
Old 20th August 2009, 18:37   #34
frankmehta's Avatar
Thanked: 2,334 Times
Dude, first thing... my name is Arun! Ana sounds too girlish
Take a look at the manual and there are a few guidelines given on what to do when the car refuses to start on the first crank.
Any thoughts on this, BHPians?
hahah. arun. sure thing. will have it checked by the A.S.Ses at the A.s.S.
I will refer to the manual. It's exhaustive and a fun read, but I haven't gotten it up.
What's a GEM module? Did you have the same problem too???
Is this a factory defect in all Fiestas?
And about the grind, I get it sometimes, but in all cars I drive, since i do a lot of half-clutching
frankmehta is online now   Reply With Quote
Old 20th August 2009, 20:10   #35
sathee46's Avatar
I dont think so, i had experienced this may be once. Only after going through arun's thread i came to know the ECU was the culprit. The GEM module was replaced because I had an issue of the remote boot release not working at times. The GEM module is what controls all the electronics in the car. I also came to know that starting trouble is a known problem from the service advisor. After they had replaced the GEM, the ECU was also reset. I've not had any problem since.
P.S - Frank if you plan to claim anything on warranty in the electrical stuff get it done before you get any ICE inside the car. Hope you already know about ford's stringent warranty norms. Even if your horns are changed they could reject your claim easily.
Old 20th August 2009, 20:36   #36
nitrous's Avatar
Thanked: 285 Times
So, were you remapped from an 'S' map to a 'zxi' map?
Old 20th August 2009, 21:03   #37
sathee46's Avatar
No, It was delayed for a while just to get the remap of the 'S'. You know how long i waited for it
Old 21st August 2009, 09:25   #38
frankmehta's Avatar
I am going to the service center tomorrow. Will update what happened, here.
Old 21st August 2009, 09:54   #39
anachronix's Avatar
Thanked: 1,294 Times
Guys,
Is the mapping different for a ZXi & the 'S' !?
anachronix is offline   Reply With Quote
Old 21st August 2009, 10:02   #40
frankmehta's Avatar
Yes, it is! Heard it from the horse's mouth (service guys)
Old 21st August 2009, 10:39   #41
anachronix's Avatar
Damn! I need to get the remap done again. :(
Old 21st August 2009, 10:47   #42
frankmehta's Avatar
Why?? The ecu in the s already comes with a different map. Why do you want reflash the same software???
Old 21st August 2009, 10:50   #43
sathee46's Avatar
It was not just a flash, it was reset and re-programmed in my case.
Old 21st August 2009, 11:08   #44
Rehaan's Avatar
Thanked: 25,038 Times
Rehaan,
The occasional less power & unresponsiveness is there! :(
Sorry i seem to have missed your reply.
Basically i was leaning towards a clogged fuel filter or even a problem with the car's fuel pump.
.... when I am revving my engine high and shifting gears I hear a 'creak' noise when I slot into 4th Gear. Either way from 3rd to 4th or downshifting from 5th to 4th and I can hear this 'creak' noise...
Does this sound happen when you shift the gears? or when you press/release the clutch ?
I somehow doubt they have remapped the ecu. More like just reset it - would be my guess.
cya
R
Old 21st August 2009, 11:11   #45
greenhorn's Avatar
Thanked: 1,516 Times
if they ask you to use system G, do it.
At least in my case, System D really works !
Renault Scala (keyless go) : Just dies, and refuses to start hawrie Technical Stuff 23 30th October 2013 07:34
Verna refuses to start at times sajands Technical Stuff 21 18th December 2011 07:12
07 Civic refuses to start raghav.carfreak Technical Stuff 12 27th January 2011 19:58
Accent viva - refuses to start at signals bijuks Technical Stuff 21 22nd January 2010 10:53
i10 Kappa refuses to start. Battery flat? jango Technical Stuff 39 21st May 2009 13:28
