Old 4th June 2009, 09:17   #1
KRIEG150's Avatar
Question Comparisons of Engines
i am conceptualizing a 6WD atv using independent suspensions on all six wheels and skid steering system. I have finalized all other tech aspects except one primary thing - the engine . The points that are kind of bugging me are selection of engines from the two options i have finalized:
1. Pulsar150 (1st gen): I have this engine from my past gokart project
(refer http://www.team-bhp.com/forum/introd...etting-me.html (Thanks for letting me in!))
the specs:
Power: 11bhp @ 8000rpm (apprx)
Torque: 11Nm @ 7000rpm (apprx)
2. Bajaj Rikshaw 180cc engine: a small engine compared to the torque it generates. Also, it is one of the cheapest engines to maintain and very mechanic-friendly too
the specs:
power: 8bhp @ 5000rpm
torque: 11.5Nm @ 4000rpm
now as a general rule, power = torque X rpm x "some constant"; by that analogy, the P150 appears more powerful than the rik. But then, riks have been known to carry much heavier loads (though a bit sluggishly) whereas the pulsar is fast and quick.
Are the engines equally matched? all that my ATV would need is torque since i want skid-steering in it. Please advise.
KRIEG150 is offline   Reply With Quote
Old 4th June 2009, 11:21   #2
alpha1's Avatar
Thanked: 1,035 Times
More torque at lower RPM means you can run your gears at low RPM without shifting down.
It also means you can start off with less clutch slip, low revving.
Converse is true for higher torque/RPM at higher RPM. You don't need to upshift, you can zoom by just revving the engine.
It all boils down to your application.
Old 4th June 2009, 11:54   #3
sgiitk's Avatar
Thanked: 3,883 Times
For an ATV you will need a lot of low end otrque and should not be too worried about the high end power.
Also, your chassis reminds me of the Tatra Trucks of the Army. They apparently have a backbone structure with each apir of wheels allowed to flex independently. You may call it a Caterpillar design, with a backbone allowing individual axles a lot of flexibility.
Old 4th June 2009, 13:17   #4
KRIEG150's Avatar
@sgiitk
Also, your chassis reminds me of the Tatra Trucks of the Army. They apparently have a backbone structure with each apir of wheels allowed to flex independently. You may call it a Caterpillar design, with a backbone allowing individual axles a lot of flexibility.[/quote]
i am fan of all variations of TATRA trucks - they use modified de dion half-axles with a combination of leaf springs and pneumatic dampers. my design however has the basic mcpherson with bell-crank lever and horizontally mounted shocks(primarily to save space)
Old 4th June 2009, 20:02   #5
Shan2nu's Avatar
Thanked: 89 Times
Only looking at an engine wont tell you the complete story, gearing plays a much larger role in transfering torque to the wheels, which explains why the 1st gear in a car has so much more pulling capability than the 5th gear, even thought the torque/power comes from the same engine.
So if you can sort out the gearing, the Pulsar engine would be better or else stick to the other one.
Shan2nu
Old 4th June 2009, 20:24   #6
Technocrat's Avatar
Thanked: 2,589 Times
Just a small correction P150 classic produced approximately 13 bhp at 8000 rpm
Why dont you try to source a Karizma engine it has more power & torque at relatively lower RPM
Power - 17ps@7000 RPM
Torque - 18.35Nm@6000 RPM
Old 4th June 2009, 20:37   #7
KRIEG150's Avatar
@technocrat
thanks for the information update; i couldnt get the figure fr P150 (1st gen) so felt it might a a couple of horses lesser than the dtsi's
@shantanu
probably, an option that i have is to use the P150 engine and manipulate & increase the sprocket size of the final transmission shaft so that in any given gear, i get a higher torque at the wheels (SIX of them in fact) than the stock P150. it seems, well, a pretty straight forward course from here onwards. Thanks for the support guys!
Do modern common-rails engines last like IDI/DI engines? Gany Technical Stuff 39 21st March 2015 08:53
Do Diesel engines generate more Torque than Petrol engines? ex670c Technical Stuff 224 25th November 2013 12:20
Segment wise Car Comparisons between the Rivals! raj_5004 The Indian Car Scene 27 17th September 2011 12:38
Difference between old engines and new engines (petrol and diesel) srijit Technical Stuff 32 26th January 2011 10:20
VW CRDi engines Vs Toyota CRDi engines ivar1951 The Indian Car Scene 9 20th September 2009 22:24
