Old 5th June 2009, 21:55   #1
Default SX4-Power steering connector just below cold refrigrant line
I have observed one thing in my SX4. Power connector to power-steering is just below the cold refrigerant return pipe from inside of the cabin. When the line is cold, water condenses on the line and then drips on the connector. Water and electrical conductor is not a good combination. I don't know if the connector is water tight. If it is not, then water will enter there and corrode the copper in connector, resulting in long term reliability problem.
Experts please voice your opinion. Should I do something to shield the connector from dripping water.
Thanks in advance
strips007 is offline   Reply With Quote
Old 5th June 2009, 22:37   #2
vigsom's Avatar
Thanked: 581 Times
Default Paani aur aag
Two arguments here:
  1. Yes,it would be better to shield the connectors so that you eliminate any chances of a the terminals getting coated
  2. On the other hand,also please undertstand that the same risk exists whenever a car is water washed(serviced)
Nevertheless,I would recommend that the connector be shielded with some good flexible plastic.
Maruti Esteem - Non Power Steering to Power Steering udit78 Modifications & Accessories 14 4th May 2011 13:29
water inside sx4 - power steering issue ravindra_hyd Technical Stuff 11 16th September 2010 20:19
Power steering to manual steering? ramzsys Technical Stuff 18 11th August 2010 23:16
Electric Power Steering Vs. Hydraulic Power Steering joseph5600 Technical Stuff 3 19th November 2007 20:56
Please suggest - power windows, power steering from one Esteem to another pramodkumar Technical Stuff 4 1st September 2006 09:19
