Old 6th June 2009, 22:26   #1
vinfriend
Posts: n/a
Default Painting Maruti 800 cabin floor & Under body
Is it good to paint cabin floor and under body of M800 (18 yrs old) to prevent corrosion? As I plan to do the floor painting myself using silver paint and brush, should I use automobile primer first?
I think it wont be wise to give it for patch & painting work which will cost around 15K.
Old 6th June 2009, 23:27   #2
Thanked: 152 Times
Well you should go in for rubber based paint it lasts really long .On my 800 it is there from last 5+ years and got done in just 1000 Rs for the wheel wells and the undercarriage.But please do not get it done near silencer/exhaust. Also this way it will be water proof and does noise insulation also.
Trust_In_Thrust is offline   Reply With Quote
Old 6th June 2009, 23:40   #3
msaudf's Avatar
Thanked: 152 Times
hello there Vin. painting the platform of the car is good as long as you get the floor cleaned and there are no rust spots. i hope you dont have huge rust spots cus then its better you get them patched. and priming the floor will not help much unless you expose the metal and prime the metal and bulid on that by giving it a paintjob. for the underbody a good wash untill its squeky clean and just apply paint. use a brush cus the coats will be thicker then.
have fun.
msaudf is offline   Reply With Quote
Body Repair & Painting, Glass Repair, Detailing etc. - Trend Automobiles (Bangalore) decode Bangalore 291 16th June 2018 10:59
Body Work, Painting & Polishing - Anshumaanh (Cochin) wilful Other Cities 9 17th July 2017 17:05
Maruti 800 STD & 800 DX..pros & cons ? shapath Technical Stuff 6 21st August 2015 11:32
Painting and Body Work Shops in Mumbai ported_head Modifications & Accessories 16 31st January 2015 18:52
Indica XETA 1.2 BOdy repair + painting cost? neel12345 Technical Stuff 0 6th September 2007 13:07
