Old 9th June 2009, 09:04   #1
Default Check Engine light comes up in Indica
Hello Guys,
I am having an indica Diesal V2, for some time I have observed that Check Engine light comes up while driving and at that time even the RPM too will come to Zero !! The problem is seen when ever I start the car after a gap of 3-4 hrs, then initailly during start the Engine light goes off and everything looks ok but after going a distance of 2-3 KM's it starts glowing. At that time I have noticed that the temp gauge to be always at Zero.
whenever engine light comes up I stops my car switches off, then again start and the engine light is gone but temp guage is still at zero only.
After doing this stop start three to four times the temp guage needle comes up a little bit and thereafter the engine check signal light never comes up. This has been going on for more than 2 weeks now. Can some one tell me what is the problem and is it a serious one that needs to be attended in a priority or should i wait for next service.
Pradeep
usrivpx is offline   Reply With Quote
Old 9th June 2009, 12:04   #2
sgiitk's Avatar
Thanked: 3,884 Times
Looks like a case of poor electrics / bad sensor for the water temperature and/or a bad thermostat.
Old 9th June 2009, 14:01   #3
trrk's Avatar
Thanked: 13 Times
See if this helps.
Yahoo! Groups
trrk is offline   Reply With Quote
Old 10th June 2009, 07:58   #4
In addition to that I today only noticed that whenever Engine light is glowing both temp guage as well as RPM needle to be at Zero .
Old 10th June 2009, 08:10   #5
greenhorn's Avatar
Thanked: 1,519 Times
if the light is on, contact your local TASC. If you drive around with the engine light on for a prolonged period of time, it may cause significant damage to your engine and void your warranty if you still have one
Old 10th June 2009, 12:20   #6
sgiitk's Avatar
Then it is almost certainly an electronics problem. Still I would advise get it fixed soon, since in case of a genuine alarm you may never know!
Fiat Linea: Check Engine light comes on lineattack Technical Stuff 1 2nd July 2012 12:26
1999 Baleno - Check Engine Light ecurb_jm Technical Stuff 7 22nd December 2011 11:51
Vista Tdi - Engine oil and the Check engine light turns ON skartik2 Technical Stuff 4 27th August 2009 14:50
"Check Engine" Light! adman77 Modifications & Accessories 22 31st July 2007 15:44
Check engine light mystery gbpscars Technical Stuff 7 4th December 2006 23:12
