Old 11th June 2009, 18:30   #16
Thanked: 103,705 Times
Nice post, Vigsom. Thanks for sharing.
Something most people overlook : You MUST change your brake fluid once in 2 years, irrespective of how less you've driven the car. Of course, high milers (50,000 kms p.a.) will do well with even earlier flushing.
Old 11th June 2009, 21:26   #17
vigsom's Avatar
Thanked: 609 Times
Originally Posted by Takumi-san View Post
Vigsom , nice explained. Can you please tell me if this method needs to be followed each time while replacing brake fluid ? How do I replace the fluid otherwise? Is there any valve to empty the container (I think not). So is syringe the only option? And is it necessary to empty the lines each time as well?
Takumi San,you have to ensure that the brake fluid reservoir does not go empty. You have to displace the old fluid with new by pumping the brake and bleeding from each wheel(Refer the steps I had posted and what @sgiitk had added)
Originally Posted by gpa View Post
An informative post and a good read!
MUL recommends a change every 2 years or 20,000 kms which ever is earlier, so I suppose sticking to this will work for their cars.
Absolutely,in fact I'll recommend 15000 kms or 1.5 years
Puts a small length of tube (PVC) on the 'nipple' The other end is immersed in a container with brake fluid (you can use the old fluid here).
Thank You Professor,I missed out the PVC tube
Originally Posted by prince_pervez View Post
Question: Will replacing the brake fluid improve braking. Brakes on my zen are not responding as they used to. I changed the brake pads to little effect. So do I need to replace the brake oil ?
brak fluid replacement is required only if it is over 18 months old.The effect on braking would not be significant.
Thanks for the compliment Big Boss
vigsom is online now   Reply With Quote
Old 12th June 2009, 09:43   #18
Thanked: 122 Times
And also if your car went in for a prolonged accident repair. Since, however good the workshop is, there is a chance that the car was dismantled without necessary precaution. I have used 2 brands of cars so far Ford & BMW. Believe me, the skills of tinkers & denters are limited. Have seen at the bodyshop things like brake hoses hanging loose, brake fluid reservoir cap missing & the mouth secured with a waste cloth and strip clamp!
BeamerBoy is offline   (1) Thanks Reply With Quote
Old 12th June 2009, 17:38   #19
Is the brake fluid replacement schedule more relaxed for rear brakes compared to the front brakes ? (by virtue of less usage)
Recently at 35k , i got the front pads/discs replaced and along with brake fluid too. But i would not be sure if rear brakes have been looked at in the last 35k kms.
pkumar is offline   Reply With Quote
Old 12th June 2009, 18:07   #20
ImmortalZ's Avatar
Thanked: 312 Times
Brake fluid is common for both the front and rear brakes.
Old 12th June 2009, 20:43   #21
vigsom's Avatar
Thanked: 609 Times
Hi folks,
Am adding a pic of the wheel cylinder.Just notice the prominent cut against the normal shining surface
Old 15th June 2009, 15:20   #22
Thanked: 18 Times
After Seeing this article , I am going to change break fluid this week. Thanks for syuch a good info
mandyrana is offline   Reply With Quote
Old 19th June 2009, 13:31   #23
Default Help - noise from booster
Hi !
My handbrake was not holding so got my Esteem`s brakes overhauled recently at a MASS.
As a precaution, got the rear brake cylinders and shoes replaced. The brake oil was also replaced and air bled as per procedure ( two guys - one pumping the brakes and another releasing air).
Now after all this effort, a strange noise has started coming from the booster whenever brakes are applied suddenly. The MASS says it is from the piston in the master cylinder and there would be no effect on the braking. Got an independent opinion from an outside garage, and the verdict was same.
Could anyone throw light on why the noise has come ? I am willing to change the booster to be on the safer side as Esteem does not have independent circuits for braking like the Ikon.
dashoin is offline   Reply With Quote
Old 19th June 2009, 21:00   #24
itwasntme's Avatar
Thanked: 1,735 Times
I looked at my Aveo's manual and found that GM recommends 30,000km or 3 years whichever is earlier. My Aveo has covered 14000km in 2 years.
In a quandary about whether to change the brake fluid at my 2 year service next month or follow GM's recommendation.
itwasntme is offline   Reply With Quote
Old 19th June 2009, 22:29   #25
Shakensoul's Avatar
Thanked: 222 Times
A word of caution: Brake Fluid is harmful for the skin and eyes, be very careful while handling the fluid. It will also eat through plastic and paint.
Also bleeding is best done by a experienced mechanic, incorrect bleeding might leave air bubbles inside the fluid pipes which will prove catastrophic.
Shakensoul is offline   Reply With Quote
Old 6th July 2009, 17:26   #26
vigsom's Avatar
Thanked: 609 Times
Three years should be OK - in my case I carried on and on and on for 5.5 years.
Old 7th July 2009, 11:46   #27
sgiitk's Avatar
Thanked: 3,884 Times
@vigsom: the main reason for changing brake fluid is that it being hygroscopic in nature tends to absorb moisture. The on hard braking the water can separate from the fluid and form steam. this will be like air in the circuit, i.e. no braking.
Also, since the fluid does not circulate fully, the fluid in the cylinders tends to thicken (polymerize) with age. This will take far more than two or three years. I have actually seen a Fiat where the oil was so thick that they broke the cylinder and had to replace that as well.
So stretch brake fluid changes at your own peril.
Old 7th July 2009, 15:49   #28
rkavthekar's Avatar
Thanked: 7 Times
A very good and informative post. However, likewise, changing of timing belt and other critical items are almost forced upon by authorized service centres, I don't see them pushing their clients for brake fluid change during say 20K or 30K servicing intervals. While, assuming that the owner of the car may be ignorant, to me, its duty of service advisor to educate his patrons and empahsize on importance of such matters.
Kudos for bringing up this thread.
takecare and drive safely
rkavthekar is offline   Reply With Quote
Old 9th July 2009, 12:23   #29
mithun's Avatar
Thanked: 59 Times
During my trips to service centers, what I've noticed normally is that chaps will always keep the lid of the fluid bottle open & simply fill it in all the vehicle. They are not bothered about the fact that fluid is hygroscopic !
Another problem is that they will use DOT 3 in the place of DOT 4.
Old 9th July 2009, 15:49   #30
sgiitk's Avatar
A few minutes exposure will not matter. You cannot fully seal the lid since air has to go in and out as the fluid level changes.
As long as you do not mix the two it should be Ok. Also, does the car really call for DOT4!
Anyone using DOT 5.1 brake fluid?? Shan2nu Technical Stuff 28 11th April 2018 17:21
Brake fluid/Parking Brake Indicator light- Is this a problem? santosh.s Technical Stuff 10 7th June 2017 14:02
Brake Fluid Help! rohanarthur 4x4 Technical 4 6th July 2009 10:21
Brake fluid leakage- help required! santosh.s Technical Stuff 53 11th March 2009 23:16
Spark, Santro, i10 or others - FE important - 1500kms/month, Rear seat not important monishdesign Hatchbacks 7 11th March 2008 12:27
