Old 12th June 2009, 03:43   #1
girlieonwheels's Avatar
Default How bad can engine check indicator be?
Hi Everyone,
I have a question.
I wanted to know how bad it can be to have a car's engine CHECK indicator on, the one that's next to the odometer.
If you don't get what I am saying, I am talking about the "CHECK" light that lights up when you turn on your car and then once its on, the light goes away. Next to the Battery indicator...!
And how bad it can be if that light stays on all the time...I mean it does not go out, even when driving.
Please help.
I am wondering what can be the possible reasons, and if I really need to get it fixed urgently or pull on this way for another few days.
Thanks in advance.
girlieonwheels is offline   Reply With Quote
Old 12th June 2009, 06:19   #2
aah78's Avatar
Thanked: 1,751 Times
Arrow generic indicator
The Check Engine / Service Engine Soon light (CEL) is an indicator that's lit whenever the car computer (ECU) detects some electronic sensor isn't performing it's intended function.
Unfortunately, the nature of the problem can't be foretold by just looking at the light.
It can be a failed oxygen sensor, a leak in the exhaust system, or as trivial as a loose fuel tank cap.
The error codes need to be read by plugging in an OBD (On Board Diagnostics) reader, which is what the new-age mechanic at your local stealership does.
Usually, there's a sequence of reset cycles that the car goes through everytime you start it up and drive it around for a while.
The light is Yellow.
If your CEL comes ON but goes OFF after a few days automatically, then you should be OK, but if it hasn't gone OFF after a few days you need to make an appointment with your workshop.
Depending on your car's make & model - if the light's turned Red, then you probably shouldn't risk driving around and take the car to the workshop immediately.
My 2001 BMW, had it's CEL stuck on ON for a while - no matter what the mechanics tried. The car wasn't polluting, the engine was in perfect condition, and the BMW mechanics were pulling their hair out by the roots but nobody could figure it out - eventually they suggested changing the ECU.
aah78 is online now   Reply With Quote
Old 12th June 2009, 06:54   #3
greenhorn's Avatar
Thanked: 1,518 Times
if you have a petrol indica, the light would probably come on if you sneezed too hard
Old 12th June 2009, 07:37   #4
@aah78 - I think I will let it be like this for a while and then maybe take it to the service center. Thanks !
@greenhorn - I have a Mazda 626 in otherwise immaculate condition.
Old 12th June 2009, 08:20   #5
Thanked: 21 Times
" I have a Mazda 626 in otherwise immaculate condition. " .... WOW !! I'm impressed .. any pics ?
revvhed is offline   Reply With Quote
Old 12th June 2009, 11:11   #6
pranavt's Avatar
Thanked: 274 Times
Driving around with the CEL on isn't a very smart thing to do. It could be something harmless, or it could be more than that. Getting the error code through the OBD scanner doesn't take more than a few minutes and a little amount of money.
Old 12th June 2009, 12:30   #7
tsk1979's Avatar
Thanked: 16,421 Times
Best case, the light is faulty, worst case your engine is Kaput. So it depends. It can be anything from a simple 2 minute repair job to expensive fuel pump/rail etc., replacement.
That said if there is absolutely no problem in performance etc., and this light is coming on, its mostly some sensor acting up.
Old 12th June 2009, 14:32   #8
Thanked: 245 Times
Usually the ECU is programmed to make the vehicle "limp" before it can cause a serious damage to the engine, for eg overheating, its called the "Limp home mode" but on the other hand the sensors can detect and pre-warn before something fails and if not corrected can leave you stranded.
Get it checked at the first instance, its a 5 min job to identify whats causing it to glow
Old 12th June 2009, 15:49   #9
simply_sunny001's Avatar
Thanked: 15 Times
@GirlieOnWheels
You need to get this checked ASAP. It can be a faulty sensor or maybe more.
OT how old is she i mean your 626 ?
simply_sunny001 is offline   Reply With Quote
Old 12th June 2009, 15:56   #10
anurag_p80's Avatar
Thanked: 7 Times
ROFL....that is one APT term, man!!!
@GirlieOnWheels, as suggested, don't risk driving around with the CEL on. Better to get it checked as soon as possible. Big fault or small, why take the chance with that lovely car?
anurag_p80 is offline   Reply With Quote
Old 12th June 2009, 18:52   #11
depends on your day -
- If lucky then nothing
- if not lucky then everything
dont take risk , have it sorted out at earliest.
passion4cars is offline   Reply With Quote
Old 20th June 2009, 23:01   #12
Got it fixed, thanks for your suggestions.
It was my lucky day - nothing major.
Old 10th November 2009, 14:41   #13
Unhappy "Check Engine" Indicator light on
Guys,
The "Check Engine" Indicator light came on as I tried to start my Indica DLG car this morning. It was working fine till the last time I used it and now it wont start. Please advise me what could be the problem and how to resolve it.
SK
sakashy is offline   Reply With Quote
Old 10th November 2009, 15:27   #14
Jaggu's Avatar
Thanked: 8,692 Times
One of the fuses or relays might be blown, since it was running normally earlier. get a good technician and check. Ofcource do update here also.
Old 10th November 2009, 15:31   #15
shishir_bn's Avatar
Thanked: 108 Times
Dude can you please let us know what had happened and how did they manage to fix it. Many ofour vehicles have the problem.
shishir_bn is offline   Reply With Quote
5009 KMS-A'bad-Calicut-Bangy-Hyd-Aur'Bad-A'Bad-Report ramkya1 Travelogues 48 4th August 2010 00:04
A bad bad bad night for me.... Ranjan Sharma Street Experiences 38 8th April 2010 12:02
Can indicator/wiper levers be swapped in Skoda? silverbyte Modifications & Accessories 5 2nd July 2009 09:04
My accident - Bad brakes, bad rain, bad luck... vezj420 Street Experiences 41 22nd May 2007 10:49
