Old 12th June 2009, 21:22   #1
akhilesh51's Avatar
Thanked: 336 Times
Default Engine losing power in Vista MJD
I came across this weird problem in my Vista MJD Anniversary edition when on a long drive sometime back.
When above 70 kmph, The car loses all power for few seconds. It is as if the gear has been shifted to neutral with no acceleration. The car gradually loses speed for few seconds before getting back to normal.
It happens intermittently but always above the speeds of 70 kmph. Once it happened 4 times in a trip of 120 kms, on return trip it did not happen at all and once again today, on the same trip it happened once.
This problem has left the service people scratching their head ( I actually didn't expect much from them either)... Anyone on this forum has experienced this problem ? Is their a solution to this ?
akhilesh51 is offline   Reply With Quote
Old 12th June 2009, 21:47   #2
revhappy's Avatar
Was this happening with AC on? A wild guess; Could it be due to the AC thermostat cutting in and out?
revhappy is offline   Reply With Quote
Old 12th June 2009, 21:59   #3
Zappo's Avatar
Thanked: 2,081 Times
Maybe I did not get this problem at all. How do you know that the engine is loosing power? Is it by looking at the speedo or is the difference perceptible enough for you? The confusion here is because of your statement
What happens if you press accelerator at this time? Does the engine revvs freely like in neutral? Or is it that you do not feel that happen at all(as in free revving) even if you press the accelerator?
My suspicion is that it is an electrical/electronics problem. Your meter is probably creating an illusion for you.
Also, are you sure that your clutch is not heating up too much?
Zappo is offline   Reply With Quote
Old 12th June 2009, 22:03   #4
dockap's Avatar
Thanked: 378 Times
yes i have had the same problem 3 times when driving my wifes vista qjd and like you said it happens at 70 to 80 kph while accelarating problem seems to have disappeared after the 5k service
dockap is offline   Reply With Quote
Old 12th June 2009, 22:18   #5
live2drive's Avatar
Thanked: 25 Times
Adulterated fuel maybe?
live2drive is offline   Reply With Quote
Old 13th June 2009, 01:28   #6
Thanked: 660 Times
Unlikely!!
What gear were you on.?
Old 13th June 2009, 02:29   #7
asethi's Avatar
Thanked: 40 Times
Akhilesh I understand your problem. I too faced the similar problem in my Swift DDiS, but only when the AC was on. But after the service last week, the problem is no longer there.
asethi is offline   Reply With Quote
Old 13th June 2009, 11:55   #8
akhilesh51's Avatar
Thanked: 336 Times
AC was on all the time.
On speedo Car is losing Speed. Personally too, I feel that engine loses all rev power. If I further press the accelerator, Nothing happens, car continues to lose speed.
It is certainly not an illusion and I know it for sure because the speedo only problem happened in my Palio 1.6 Sport. Here, Car actually loses power and speed.
Highly Unlikely. I fill up at my own fuel station
Fifth Gear
Old 13th June 2009, 12:13   #9
Thanked: 245 Times
Hope you also noticed the temp indicator at that time, was it normal ??
If not for heating, this can happen for multiple reasons.
- Check for water in the sedimenter
- When was the last time you changed your fuel filter/ Air filter
- EGR valve sticky or faulty
If under warranty, ask them to change(FF/EGR/AF), if not clean (EGR/Sedimenter/AF)
PS: Forgot to ask, was it happenning from the beginning or came up later, if later, you might first want to reset your ECU.
Old 13th June 2009, 15:15   #10
Thanked: 660 Times
dude! its overdrive. are you sure you are shifting at the right rpm.
Old 13th June 2009, 15:38   #11
Yes, that is exactly what I was about to ask.
janitha is offline   Reply With Quote
Old 13th June 2009, 16:51   #12
Thanked: 242 Times
I think your problem is in turbocharger. This problem occured in swift lot of times now in Vista this is surfaced. This might be a problem with all fiat MJD engines.
Do you keep engine idle for 30 seconds after starting and before shutting? Because this is must do for Turbo charged engines, otherwise you may face problem in turbocharger.
sushantr5 is online now   Reply With Quote
Old 13th June 2009, 17:53   #13
kpzen's Avatar
Thanked: 1,655 Times
Was the fuel filter changed during the service?
Old 13th June 2009, 18:02   #14
rkg
Thanked: 543 Times
It happened in my vista few times. especially when the speedo was at 60 km and the car was in 4th gear. I felt as if car is not gaining any speed even after accelerator was fully engaged. after few seconds leave the accelerator and then press again car gains speed. there was no indicator light on panel. i did not observe temperature. next time it happens i will observe temp
no free revving sound was observed. it happened before third service.
rkg is offline   Reply With Quote
Old 13th June 2009, 18:49   #15
greenhorn's Avatar
Thanked: 1,519 Times
question. Was the needle at the point where both the engine fan and the compressor fan both cut in ( big fan sound?) At that point, engine is slowed down, and if AC is on, severely.
Did the happen when the sun was up ( ie air is not cool)
2007 Indica Xeta: Engine losing power all of a sudden and regaining power after mins mohandas Technical Stuff 17 3rd May 2016 07:37
Honda Unicorn losing Engine Compression - HELP kkg Motorbikes 51 24th May 2015 12:17
ICE for Vista Limited Edition without losing boot space koushikvenkat In-Car Entertainment 12 15th January 2011 23:23
Indica Vista MJD vs Palio MJD vs Swift DDiS greenhorn The Indian Car Scene 452 24th April 2010 18:11
Wobbling and Losing Pickup after a accident-indica vista hdi_pro Technical Stuff 12 6th November 2009 18:12
