Old 15th June 2009, 19:13   #1
Thanked: 59 Times
Default Air screw adjustment on carb zen
Hi
could any body help me with airscrew adjustment on a carb zen? Does the screw tightening make the mixture rich? I was told opposite views by 2 MUL technicians here in bangalore, now sort of confused!!
I though believe that air screw loosen means 'lean' and air screw tighten means 'rich'!! Help me guys!
Also i read that air screw adjustment with gas analyser is to be done at high RPM's to realise best effeciency (average running RPM, but not at idle), and what practise followed by the workshops (idle setting) is actuallly wrong!! any comments from core techies, if any in here??
gopa99 is offline   Reply With Quote
Old 15th June 2009, 21:46   #2
Jaggu's Avatar
Thanked: 7,478 Times
Screw out will lean the mixture. As far as i understand its the idle circuit, and tuning at a lil raised idle (200-300 rpm more) is the right way to set it correct. Helps in correcting the flat spots that come during the transition from idle to main circuits. At higher revs and very high revs main jets take over which doesnt have any air screw effect.
Old 16th June 2009, 01:21   #3
techn0l0gist's Avatar
Thanked: 27 Times
It is actually the opposite,even I used to think the same way earlier, however tightening it will make it lean
quotes from the service manual, all workshops follow this method, the exhaust gas analyzer is used optionally as the last step to fine tune the idle mixture screw :
Note that the procedure below is for the G13 engine which came with the esteem/gypsy, since the mikuni carb is almost the same for the zen, i guess tuning procedure should be the same.
techn0l0gist is offline   Reply With Quote
Old 16th June 2009, 04:42   #4
Thanked: 27 Times
continued from prev post - this is the last step in the adjustment procedure (the values for CO below are for the models without catcon, for the catcon equipped models, I think they'd be 0.5-1.00)
Old 30th June 2009, 12:46   #5
Hi techn0l0gist, Can you please tell me the exact number of turns, after full tighteninig of screw that will result in best power & mileage ratio.
buddy is offline   Reply With Quote
Old 30th June 2009, 14:45   #6
sgiitk's Avatar
Thanked: 3,759 Times
@buddy: There is no hard and fast rule. Each car has its own ideal.
sgiitk is online now   Reply With Quote
Old 30th June 2009, 20:06   #7
Jaggu's Avatar
Oops my bad thanks for the correction technologist, i was thinking from a slider carb set up
One method to set it right is, adjust the RPM to max using idle screw (slightly raised RPM helps) and from that point, 1/2 turn towards richer side. Very crude but works most often.
Right approach is using a gas analyzer.
Weird Problem after Spoiler install. Screw stuck in the trunk lid aseem Technical Stuff 12 31st January 2012 12:06
chassis mounted screw type jack. siddartha 4x4 Technical 6 20th November 2009 21:13
Helmet Visor Screw Lost! Cant Find a new one rahulsingh007 Motorbikes 12 20th February 2009 20:26
99'ZEN carb to ZEN mpfi.... Balram Modifications & Accessories 17 10th December 2006 09:04
shogun's air screw setting Rice_tuner Motorbikes 4 18th September 2005 13:07
