Old 15th June 2009, 21:56   #1
rrsteer's Avatar
Thanked: 937 Times
Default M800 - Strange Thuk-Thud noise
Want to seek the forum for help regarding a strange noise that comes from my M800. The car in question is 2 years old. The noise is a thuk - thud noise which I hear when I pull her in first gear. This is especially true, when I decelerate through the engine and pull the running car in first gear. And sometime I can hear the same noise in slow speeds while I pull through a corner in lower gears. Notice - the sound is not heard everytime I do the above routine.
This noise has been there eversince I have got the car. Have taken the car to various authorised service stations and no one has been able to diagnose the fault. Mostly whenever the car is in the service station, the mechanics even fail to replicate the sound
Otherwise, the car is running fine and has clocked around 23K kms and has given no other cause of concern.
Will look out for your responses.
rrsteer is offline   Reply With Quote
Old 15th June 2009, 22:09   #2
Thanked: 253 Times
Is it a mechanical sound or more like exhaust system sound?
anupmathur is online now   Reply With Quote
Old 15th June 2009, 22:51   #3
Jaggu's Avatar
Thanked: 8,694 Times
Have your mechs checked the engine/gear box mounts in the car? Exhaust headers if it is touching body in the front?
Old 16th June 2009, 12:24   #4
rrsteer's Avatar
Thanked: 937 Times
Its a mechanical sound.
I'll get the engine and gear box mounts checked.
Old 16th June 2009, 14:00   #5
Thanked: 41 Times
- yes. But check the contents of your boot. Sometimes it is an odd item like a mug or bucket that you keep in the boot or an unsecured Stepney / jack / tools bag that is the cause.
cnaganathan is offline   Reply With Quote
Old 3rd July 2009, 15:39   #6
Mr_Bean's Avatar
Thanked: 142 Times
I am not an expert in this
Could be a lower arm problem, normally it comes with a bush & if it is worn out then you could heard thud thud sound. I had this noise on my car when I used to accelerate & brake hard on an open/bad stretch.
If you hear this while taking turns, then you need to check drive shaft. If you hear the sound when turning right, then the left drive shaft can be weak & vice versa.
Mr_Bean is online now   Reply With Quote
Old 3rd July 2009, 17:11   #7
aaggoswami's Avatar
Thanked: 1,542 Times
If lower arm is the problem then one can have some feel of irregular movement of wheels in the steering. Moreover a bad lower arm can ruin the tyres within very short time. But this is the problem ever since the car was bought. I think it might be related with suspenision if engine mounts are good.
I feel its suspension, may be the front. Apron might not be in perfect shape, but this is a long shot. If mounts are good, then suspension needs to be checked.
aaggoswami is offline   Reply With Quote
Old 3rd July 2009, 18:41   #8
Psycho's Avatar
Thanked: 95 Times
Can you also ask your mechanic to check for a diff fault or low oil level in the gearbox.
A loud 'thud' sound whenever my Ford Ikon passes over potholes on the road. InternetUser Technical Stuff 24 25th June 2013 21:38
Need advice - Thud Sound while taking IKon out from Parking FlairBoy Technical Stuff 10 8th September 2009 19:52
What's so assuring about the door thud? subscrive Technical Stuff 34 20th August 2009 11:28
Strange humming noise from my Safari(EDIT: Solved, window was open hence the noise) himanshugoswami Technical Stuff 14 14th May 2008 15:00
Wake up to a THUD .... SCREE...CH...SCREECH.... DRC Street Experiences 6 5th September 2006 12:05
