Closed Thread
Old 16th June 2009, 02:15   #1
.anshuman's Avatar
Thanked: 9,159 Times
Angry ABS light on after windshield film installation in elantra
I got windshield film installed today in my Hyundai Elantra CRDi,however after the installation the ABS light and tcs off light has come on,it did disappear for a while but it came back.
I called up my service advisor he says its due to water seepage below dashboard at the time of installation of the film,he has asked me to let the car parked in sun for some time and the light will disappear and if it doesnt i will have to get the car scanned to get to the problem and to get the error erased.
Any idea what might have happened?and is my service advisor correct?
.anshuman is offline
Old 16th June 2009, 02:29   #2
ghpk's Avatar
Thanked: 193 Times
Did you got it installed from the Hyundai Authorized service center itself.
ghpk is offline
Old 16th June 2009, 02:33   #3
Akshay1234's Avatar
Thanked: 7,242 Times
the abs and tcs controllers must be under the dash. let it dry up. if it does go away on its own or by erasing the error just do a trial run to make sure its working. testing tcs is easier.
Akshay1234 is online now
Old 16th June 2009, 02:49   #4
.anshuman's Avatar
i tried ABS and TCS,its not working,i braked hard on a newly made empty road the car skidded like a accent and the yokohama db's smoked badly like a f1 car.
Waiting for sun.
Old 16th June 2009, 04:19   #5
This is definitely due to water seepage in the dashboard. Swift diesels also have this issue -- only difference being that the ECUs burn out.
thermalpaste is offline
Old 16th June 2009, 09:33   #6
ashthedivx's Avatar
Thanked: 22 Times
I would suggest to let it dry in bright sunlight and reset ECU at night to erase error code. I believe problem will be resolved.
ashthedivx is offline
Old 16th June 2009, 11:25   #7
stefanm's Avatar
Also if you have bright sunshine, i would suggest keeping all windows open as much as possible to allow the moist air to escape this will help. In heavy rains last week i had water come into the window winder switches of my Safari, this caused one window to go down on it's own, not much fun for the Mrs as it was her window, the next day the problem was still there, i knew there was no point taking it to TASS we just left the car in the sun with the windows down problem was gone in just 3-4 hours.
stefanm is offline
Old 16th June 2009, 11:27   #8
.anshuman's Avatar
Is there a seperate controller for abs and tcs or are they controlled through the main ECM?
Old 16th June 2009, 11:36   #9
Eddy's Avatar
Thanked: 5,074 Times
Anshuman,
Something related here. Please check
http://www.team-bhp.com/forum/modifi...d-sunfilm.html (CAUTION!!! Swift Owners installing Front Windshield Sunfilm)
Eddy is online now
Old 16th June 2009, 11:37   #10
gpa
gpa's Avatar
Thanked: 282 Times
This sure sounds like a case of water entering the control unit. Happened to an Omni that we owned many years back after the driver literally hosed down the insides with water engine was behaving funny for a few days as water had enetered the ECU. One evening, returned to the car after it was parked in the sun the whole afternoon and the problem disappeared. So get your car baked in the sun, it should work.
gpa is offline
Old 16th June 2009, 11:51   #11
.anshuman's Avatar
Keeping my fingers crossed i have parked my car in sun on a concrete surface,its a white car and it has film on front glass so it will take time to heat up.
Old 16th June 2009, 16:51   #12
gpa
gpa's Avatar
Thanked: 282 Times
Its been a few hours now...Has the baking helped?
gpa is offline
Old 16th June 2009, 17:13   #13
.anshuman's Avatar
Thank god the lights have gone off now and all abs functions are working fine.
Thanks everybody for your replies.
Old 24th December 2009, 02:29   #14
Zappo's Avatar
Thanked: 2,080 Times
So your service advisor was indeed correct. It was a case of water seepage.
Zappo is offline
Closed Thread
Sun Film or Security Film? lambuhere1 Modifications & Accessories 18 21st May 2013 11:57
Removing Sun Film from windshield with defogger. JayD Technical Stuff 40 7th May 2012 13:41
Garware agrees no suitable windshield film by them sinhsha Modifications & Accessories 26 10th August 2010 15:06
Effect of solar film on the rear windshield (with Defogger) hbaruas Modifications & Accessories 1 11th March 2008 14:44
Elantra GT vs Elantra Crdi(Was skoda vs elantra) azifali Sedans 39 17th August 2006 12:56
