Old 19th June 2009, 19:05   #1
Spinnerr's Avatar
Thanked: 140 Times
Default Tips to drive better: But are the tips correct?
Today at our office we had this email circulated. It was done with an intention to make people aware of simple things that can increase their carís mileage, in turn reduce the fuel consumption, in turn the impact on this environment. Its part of the ďGO GREENĒ campaign. All for good.
There are 2 points in the mailer that I know are not correct, I would like reply back to the concerned department / person who prepared this so that they could send a 'corrected' mailer across.
Now, I would like to have some solid facts to go along with my mail, may be a couple of links that I can point out as reference. Here is where I would need your help. PLz do pitch in
Tips to drive better: But are the tips correct?-tips.jpg
Here is my take.
* If you ride around in crowded street with clucth depressed, and if some one jumps in front, and you break a bit late. BHAM, you crash, isnt it? Where as if you had the clutch engaged, there would be some amount of engine braking, so your pressing brake adds on to that, better/faster chances to slow down.
And I feel majority of the people driving in the city use more clutch than needed to negotiate the bumper-to-bumper traffic. Isnít it also true that when you accelarate and declutch then there is some unburnt fuel. Does that mean more the pollution or would that mean less carbon in the air, cuz the fuel vapours escape out?
* The next point, avoiding 1st gear to start the car from stand-still, which is entirely wrong, isnít it? After all the car needs all the power to get off that inertia. Starting off in second gear could strain all the cars mechanicals, more over, higher the gear, you need more rpm to get the car moving, so that would mean more fuel burnt. No saving. Correct?
Any more points?? Facts??
Spinnerr is offline   Reply With Quote
Old 19th June 2009, 19:16   #2
DieselFan's Avatar
Thanked: 233 Times
Using clutch in crowded places to save fuel. What a Joke
Using clutch more often not only uses additional fuel but fries the clutch faster and also you end up replacing the brakes faster.
Starting the car in 2nd or 3rd gear is sureshot way of frying the clutch early and you end up with huge clutch replacement bill. who the hell came up with such brilliant innovative ideas. Hats of to that person.
DieselFan is offline   Reply With Quote
Old 19th June 2009, 19:26   #3
McLaren Rulez's Avatar
Thanked: 474 Times
Does engine braking consume fuel? I thought that the more throttle you give, the more fuel goes in. By that logic, engine braking where no throttle is given should result in no more fuel consumed than idling right?
McLaren Rulez is offline   Reply With Quote
Old 19th June 2009, 19:28   #4
techn0l0gist's Avatar
Thanked: 27 Times
and what if you happen to own a skoda !
techn0l0gist is offline   Reply With Quote
Old 19th June 2009, 19:34   #5
BenjiRoss's Avatar
Thanked: 111 Times
Both the points mentioned above have been discussed in detail in specific threads here. (Will dig them out)
Such chain emails etc should be stopped as they cause a lot of harm!
BenjiRoss is offline   Reply With Quote
Old 19th June 2009, 21:45   #6
Gansan's Avatar
Thanked: 877 Times
Are you sure this email was not dated 1st April?
Seriously, I think both the points are utterly wrong. Driving with the clutch depressed? Then why not engage neutral after gaining good momentum on the high way? We can save even more fuel.
Old 20th June 2009, 02:01   #7
pranavt's Avatar
Thanked: 272 Times
These "guidelines" are written by a clutch manufacturer. Don't believe the stuff which you've just quoted.
Old 20th June 2009, 02:29   #8
Starting the car in 2nd or 3rd gear will have at least two ill effects:
a) It will lug the engine - ie the vehicle will move with short jerks because of inappropriate gear for the low speed. This will harm the engine and definitely lower fuel efficiency
b) It will wear out the clutch much faster since you will have to hold onto the clutch longer and release the clutch slowly when you start in 2nd gear.
Irresponsible advice has been circulated.
sridharps is offline   Reply With Quote
Old 20th June 2009, 08:10   #9
Thanked: 448 Times
you will come across a lot of such emails,regarding,health,smoking,drinking habits,and of course automobiles.such type of emails are generated taking some highly common practices and then proving that these were wrong,or were causing more harm then good(of course it uses some self made facts or research).lot of time emails will claim that * according to latest research in such n such university or something,however i have hardly seen any website links attached therewith(obvious reasons the creator of email would not like to be sued by some giant corporation hence no links. Its just another stunt to overload networks.
refer owners manual for correct procedure of handling the vehicle,a manufacturer spends lot of money in establishing correct procedure for its vehicle,after all he will have to serve warranty claims.isnt it!
dustom_99 is offline   Reply With Quote
Old 20th June 2009, 22:37   #10
Spinnerr's Avatar
Thanked: 140 Times
I shall send out a reply on Monday, shall keep you guys posted on it. This was circulated within our organization.
@BenjiRoss: Thanks for offering to direct me to threads where this is discussed.
Old 22nd June 2009, 12:14   #11
Spinnerr's Avatar
Thanked: 140 Times
Default Links
There are a bunch of threads on this. Found them here.
Old 22nd June 2009, 13:00   #12
SS-Traveller's Avatar
Thanked: 10,862 Times
Good God! Which goofy, incompetent back-office idiot wrote that? Unless, of course, your company manufactures clutch plates for a variety of vehicles! Thank God they didn't recommend that you drive around on 3rd gear for ever...
The other points are fine, though.
TATA Nano - Left Hand Drive - Is pic correct? EDIT : It's a Photoshopped image vinair The International Automotive Scene 10 4th April 2012 05:22
A 911..but Ohh So Much Better Cyrus43 Super-Cars & Imports in India 14 1st September 2007 01:08
is k&n replacement better or a cold intake better? redsfx Modifications & Accessories 1 31st May 2007 16:58
Correct way to drive/use AT sandeep108 Technical Stuff 12 8th October 2006 01:25
Better roads.. better late (than never) Laxminarayan Street Experiences 1 12th April 2006 03:14
