Old 22nd June 2009, 15:04   #1
amitk2kin's Avatar
Thanked: 42 Times
Angry Swift VXI : Flat battery. Push start didn't work?
Was off to Nasik last weekend and while we left the car with driver for a 4-5 hours, on our return the driver tried to start the car and it won’t start? On probing him, we found out that he was sleeping on the car with the music on and also the a/c blower, which lead the battery to go dry.
Tried doing “Dhaka start”, which was not help, finally had to call for a mechanic. The mechanic came with a service battery and jumper wire, that did the trick!
My question is, do all the newer cars, do not start in the 2nd gear? ( Dhaka Start)? Or am I missing anything here?
The Mech. told us that all the newer car's will not start the old fashioned way? is that true? has anyone faced such issue in the past?
amitk2kin is offline   Reply With Quote
Old 22nd June 2009, 15:37   #2
NOTORIOUS's Avatar
Thanked: 89 Times
i think it has to do someting with injectors. if no battery then no fuel and without fuel you cant start .
NOTORIOUS is offline   Reply With Quote
Old 22nd June 2009, 15:40   #3
Thanked: 142 Times
I think with MPFI cars you are not supposed to attempt a push start. The right way is to jump start with a spare battery
pypkmsrikanth is offline   Reply With Quote
Old 22nd June 2009, 17:05   #4
Thanked: 146 Times
Check the user manual (you do get one; most probably in the glove compartment).
It would be specifically stated NOT to push start the car!
HappyWheels is online now   Reply With Quote
Old 22nd June 2009, 17:13   #5
nitrous's Avatar
Thanked: 285 Times
There's no fuel going to the injectors from your electric fuel pump.
How WILL it start?
Old 22nd June 2009, 18:36   #6
Jaggu's Avatar
Thanked: 8,671 Times
If battery is completely drained yes fuel starvation can happen (nitrous explained it well), but if you had left the car idle for 10-15 mts then tried push start, it would most likely start.
NO this is NOT recommended, since it can affect the cat con of modern cars.
Old 22nd June 2009, 23:57   #7
Turbo Head's Avatar
Thanked: 83 Times
I guess it has got something to do with the ECU of the car, ECU is resetted in the event of complete battery draing and is resetted only when you jump start/replace the battery of the car and not just dhakka start.
Turbo Head is offline   Reply With Quote
Old 23rd June 2009, 09:20   #8
SS-Traveller's Avatar
Thanked: 11,626 Times
With a completely flat battery (when even the ignition lamp on the dash barely glows), no petrol car will start - MPFi OR carburetted. That's because there's no current to produce a spark at the plug. No spark, no start.
Old 23rd June 2009, 14:03   #9
devrajman's Avatar
Thanked: 116 Times
so any DIY trick when stranded?
devrajman is offline   Reply With Quote
Old 23rd June 2009, 14:13   #10
Thanked: 49 Times
DIY in this case would be limited to carrying a set of jumper cables so that you can jump start the car (using the battery from another vehicle).
CrackedHead is offline   Reply With Quote
Old 23rd June 2009, 14:16   #11
ghpk's Avatar
Thanked: 193 Times
Make your own, or buy a Jump Start Cable.
Old 23rd June 2009, 14:24   #12
hellstar's Avatar
Thanked: 17 Times
does it require that the clutch be depressed for the swift to start ? like in the verna crdi ? I have seen may an verna's being grounded because the clutch sensor had malfunctioned. then no amount of push starting or cranking can bring the engine to life.
hellstar is offline   Reply With Quote
Old 23rd June 2009, 14:29   #13
Hashim's Avatar
Thanked: 32 Times
A flat battery if given some time (unpulg ground wire) then it should be able to run fuel pump for some time till dhakka start will start the engine.
I can think of a low battery warning circuit which can trigger an alarm when battery voltage falls below 12v. These circuits are easy to make and they are cheap too.
Hashim is offline   Reply With Quote
Old 23rd June 2009, 14:52   #14
kannan666's Avatar
Thanked: 70 Times
In most cases, while the battery may not have the juice to run the starter, it will still run all the other accessories. However, it is not recommended to push start an MPFI car at all and like others have suggested here, try and carry a pair of jumpstart cables. When I go on a really long distance trip, I also carry a spare battery, especially if the battery in my car is over two years old, so that I am not stranded in the middle of nowhere with a flat battery !
kannan666 is offline   Reply With Quote
Old 23rd June 2009, 15:02   #15
sgiitk's Avatar
Thanked: 3,882 Times
The entire fuel system is electronic. Hence the ECU, fuel pump, injectors are all dead,
With a low battery you can get away with a push start but with a flat battery there is no way.
Push Button Start / Ignition jesal Modifications & Accessories 114 28th July 2013 12:18
New generation cars : Pushing to start ineffective when battery is flat? allajunaki Technical Stuff 16 13th April 2011 10:56
i10 Kappa refuses to start. Battery flat? jango Technical Stuff 39 21st May 2009 13:28
