Old 24th June 2009, 01:12   #16
khanak's Avatar
Thanked: 130 Times
What is the weight difference between an 800 a Zen and an Esteem?
Google says the 800 is 650 kgs, Zen is 765 kgs & Esteem is 870 kgs. So I guess you will be saving about 200 kgs. Not bad!
khanak is offline   Reply With Quote
Old 24th June 2009, 09:59   #17
Thanked: 53 Times
Originally Posted by Hashim View Post
I believe even if engine is mounted in rear then also high speed cornering is going to be scary. It will have the same problem which earlier model of Porche 911 had. Due to heavy rear, the vehicle may tend to spin if cornered at high speed.
Porche is a rear engined car , the engine weight is behind the rear axle, this one will be come a mid engined car as the engine [if done] will be before the rear axle.
More ideas on modding the 800.
-It will need a wider track front ans rear to stabilize it for that kind of power and high speeds and to accommodate the drive shafts.
-will to find electronic power steering.
-Discs all around, [have been working on something].
-Roll cage and body strengthening [by welding] and adding some more martial to make the front end stiff.
More later.
dinar is offline   Reply With Quote
Old 24th June 2009, 10:26   #18
Thanked: 54 Times
Originally Posted by pedrolourenco View Post
As soon as you are ready. We can start with the deconstruction first. Any idea what to do with the old 800 engine?
shall drop in sometime later in the week. do you have an old bike we can fit the 800 engine into ? on a serious note , we can just sell it and buy parts for the e-800 project !
about the booster and brakes , we can use the ones from the esteem if its a junker or we can buy them. lets make it run first and then make it run fast and then make it stop fast
techn0l0gist is offline   Reply With Quote
Old 24th June 2009, 14:44   #19
pedrolourenco's Avatar
Thanked: 617 Times
The current owner (scrap dealer) may come on board with us. In that case we'll get whatever is salvagable from the Esteem for free.
pedrolourenco is offline   Reply With Quote
Old 24th June 2009, 14:50   #20
fieroid's Avatar
Thanked: 287 Times
Nice project man.
One of my friend installed a M1000 engine in the M800 5 yrs ago. Got cams from Raj and the car was a torque bomb. The G13B should easily fit with ofcourse a few bedding changes.
All the best!
fieroid is offline   Reply With Quote
Old 24th June 2009, 14:52   #21
Thanked: 617 Times
Originally Posted by fieroid View Post
Nice project man.
All the best!
Thanks. Can I have some pictures and some tips from your friend to help me with the project.
Old 24th June 2009, 14:54   #22
D3NZ1L's Avatar
hey guys kool count me in too
D3NZ1L is offline   Reply With Quote
Old 24th June 2009, 15:00   #23
fieroid's Avatar
Thanked: 287 Times
Sorry man, the car has been sold and my friend is now abroad. However the car is in bangalore.
Old 24th June 2009, 15:16   #24
Technocrat's Avatar
Thanked: 2,589 Times
M1000 had the Zen's engine which was nothing but another generation of Suzuki Alto. So fitting that engine into Alto, M800 should not be a big problem.
Old 24th June 2009, 15:24   #25
Thanked: 617 Times
M1000 and the original Gypsy had the same engine with a Cast Iron block. The Zen engine was an all aluminium alloy unit. The M1000, Zen and Esteem had identical mounting points. The Alto & 800 should have the same mounting points. I'll need to modify the mounting points to put the esteem engine into the 800.
Old 24th June 2009, 15:29   #26
Technocrat's Avatar
Yes The construction was different but they were essentially same/similar engines.
Old 24th June 2009, 15:36   #27
Thanked: 617 Times
That means the mounting points will be the same too. So I can follow the same procedure as the M1000 mod for my project.
Old 24th June 2009, 16:07   #28
fieroid's Avatar
Thanked: 287 Times
Yup, which is why I mentioned about my friend's conversion. Its not too radical to mount the G13B.
Hope your confidence boots by now
Old 25th June 2009, 12:32   #29
Thanked: 17 Times
Pedro,
Are the length of both the engines the same? If not, you will have to move the transaxle and also rework the axles to the wheels.
Satish
VeeTee is offline   Reply With Quote
Old 1st July 2009, 16:07   #30
Thanked: 152 Times
So how far has the project gone on to ?
Trust_In_Thrust is offline   Reply With Quote
Project Titan - Apple's rumored new Electric Car Project bharat.joshi The International Automotive Scene 30 5th December 2016 19:04
Maruti 800 Restoration Project mituadas Modifications & Accessories 68 3rd January 2016 21:54
Restoration project - Maruti 800 (SS80) 1984 model the_maassk Modifications & Accessories 32 18th November 2015 11:26
Maruti 800 STD & 800 DX..pros & cons ? shapath Technical Stuff 6 21st August 2015 11:32
virtual project:old fiat into old mini cooper aadix The International Automotive Scene 3 25th April 2004 15:39
