Old 25th June 2009, 05:31   #1
Thanked: 26 Times
Question M800 - Vaporizer tube disconnected
Hello... i recently noticed that one of the tubes that leads to or from (the left one) is lying disconnected on my carb m800!? It has recently been serviced at a MASS.
I also notice a distinct smell these days around the car when i stop after a drive.
Why on earth is it disconnected? And if it is necessary for engine operation, how is the engine running?
eternalck is offline   Reply With Quote
Old 25th June 2009, 11:58   #2
humyum's Avatar
Thanked: 2,502 Times
Its mostly the Vaccume tube, It allows the secondary butterfly to open, Check it out, will lead to downing in performance.
PS: just read the heading , vaporuiser tube which goes in the black dabba ? if its that, just connect it back to its stock location in the black box!
Old 30th June 2009, 18:33   #3
Thanked: 26 Times
the tubes were connected on the dabba. The left one which goes into the carb is the one disconnected.
I had the butterfly changed because of a missing part for FICD for an AC, and it is one from an older engine. I went to the mechanic, he said the older engine did not support this functionality of a vaporizer. he just blocked this tube.
Now please tell me what function did it play and what effect will it have on the engine performance (pollution, pickup, anything).
If its something important, then i will have a new one fitted in it.
Old 30th June 2009, 23:58   #4
Thanked: 660 Times
check two things. one check the mileage of your car after the removal. also check the emission with a PUC machine.
aren't you smelling petrol odour.
Old 1st July 2009, 00:25   #5
Thanked: 26 Times
well now i'm not since he closed the open end of the tube.
and the mileage feels good, haven't got the figures yet though. will carry out a puc test tomorrow.
Old 14th July 2009, 13:39   #6
Thanked: 26 Times
i got it tested for PUC, and the result was quite surprising!
CO was at 0.002ppm (or whatever the unit is)! nHexane at 58ppm! (the previous one 3 months ago had CO at 1.15 and nHexane at 180).... is something wrong? is this normal for a pre bharat 2!? these were taken at high idle around 1100RPM.
Alternator Dependency: Will a vehicle run with the battery disconnected? anupmathur Technical Stuff 252 30th June 2009 14:13
MP3 Player gets Disconnected navdeep Technical Stuff 11 18th January 2007 16:56
M800, Neon Tube Wire getting melted, plz help nosfreak Modifications & Accessories 5 23rd June 2006 21:33
m800 vs ikon (what comp can a M800 be?) manaa45 Street Experiences 13 31st March 2005 12:06
Tubelss vs Tube etc., tsk1979 Tyre & Alloy wheel Section 4 6th February 2005 22:11
