Old 24th December 2009, 14:35   #16
pragya's Avatar
Originally Posted by adishenoy View Post
Yes you need to use a resistance because the LED has a lower voltage requirement (the voltage requirement depends on colour). The car cigarette lighter produces 12V ( a blue led requires 4V ).
Use this LED Calculator.
the link asks me following parameters to fill
Source voltage
diode forward voltage
diode forward current (mA)
I think Source volatage should be 12 volds, can you tell about others.
pragya is offline   Reply With Quote
Old 24th December 2009, 20:52   #17
adishenoy's Avatar
If you intend to run it through the cigarette lighter, the source voltage is 12 V. But, if you are connecting it to the battery, the voltage is 13.4 V (when the engine is on).
For diode forward voltage, there is a ("?") next to it. Because, different colored lights have different forward voltage.
Ask the guy from whom you purchased the LED, about the max. voltage of the LED.
Diode forward current: 20 mA
adishenoy is offline   Reply With Quote
Old 8th January 2010, 17:40   #18
sonirohit's Avatar
Excellent DIY - you are a pretty good DIY'er... Keep it up
sonirohit is offline   Reply With Quote
Old 10th January 2010, 02:45   #19
ghpk's Avatar
Thanked: 193 Times
Thanks for admiring my D.I.Y. stuff
just to update, you guys can use 330 ohm resistor too, this will help most Blue L.E.D. to run longer, few Blue L.E.D.'s were not able to sustain 2-3 months on 100ohms one.
VW Vento Cup for 2015! Replaces the Polo Cup S2!!! Indian Motorsport 7 4th August 2015 16:29
Coin Test for Tyre Wear checking mithun Tyre & Alloy wheel Section 17 29th July 2015 13:07
Coin and Currency Collectors shivshanker Shifting gears 10 30th May 2014 14:56
DIY SOS: Extra coffee cup holder in the Ritz akshay DIY - Do it yourself 14 10th November 2011 08:27
Baleno cup holder lid nisam76 Modifications & Accessories 12 18th January 2010 07:46
