Old 28th June 2009, 20:57   #1
ghpk's Avatar
Thanked: 193 Times
Lightbulb Blue L.E.D Cup, Coin holder Light, with 2 Extended/Adjustable L.E.D. Lights
Santro, Huh many dark spots, with a such a good driving experience it gives, the Inside the car was Dull and dark.
With that said, i always wanted to make it cool looking interiors, but sobor, not looking like a tempo.
Always tried to do L.E.D. work so it stays visible for purpose of eye soothing and not much bling.
Yesterday Made another LED which makes Blue glow on two Cup Holder.
the One coin holder under the Hand Brake.
Also extends the 2 Plastic pipe sleeves which can be dropped under seat, or can be focused at any other location (adjustable to be precise). 3 Blue L.E.D.'s Each side.
The Coin Slots near cup holders holds the Toggle Switch to Control these lights, and of course there's a Fuse under
the cub-holder to prevent Blown up wiring.
Enjoy
Blue L.E.D Cup, Coin holder Light, with 2 Extended/Adjustable L.E.D. Lights-backside.jpg
Blue L.E.D Cup, Coin holder Light, with 2 Extended/Adjustable L.E.D. Lights-toggleswitch.jpg
Blue L.E.D Cup, Coin holder Light, with 2 Extended/Adjustable L.E.D. Lights-shows-led.jpg
Blue L.E.D Cup, Coin holder Light, with 2 Extended/Adjustable L.E.D. Lights-glow1.jpg
Blue L.E.D Cup, Coin holder Light, with 2 Extended/Adjustable L.E.D. Lights-glow2.jpg
Blue L.E.D Cup, Coin holder Light, with 2 Extended/Adjustable L.E.D. Lights-glow3.jpg
Blue L.E.D Cup, Coin holder Light, with 2 Extended/Adjustable L.E.D. Lights-glow4.jpg
Blue L.E.D Cup, Coin holder Light, with 2 Extended/Adjustable L.E.D. Lights-glow5.jpg
Blue L.E.D Cup, Coin holder Light, with 2 Extended/Adjustable L.E.D. Lights-glow6.jpg
Blue L.E.D Cup, Coin holder Light, with 2 Extended/Adjustable L.E.D. Lights-glow7.jpg
Old 28th June 2009, 21:16   #2
DjNik's Avatar
keep up the good work .Im inspired.
DjNik is offline   Reply With Quote
Old 29th June 2009, 00:51   #3
ghpk's Avatar
Thanked: 193 Times
Thanks, replied your PM.
Hey you have nice setup as i see in your signature.
Do help me knowing options to put a good AMP in my santro
Old 29th June 2009, 10:15   #4
DjNik's Avatar
Thanks, ghpk.What kind of a amp are you looking for?
Old 29th June 2009, 11:02   #5
shreyasma's Avatar
Hey, thats a nide idea. Its come out very very well.
shreyasma is offline   Reply With Quote
Old 1st July 2009, 02:56   #6
ghpk's Avatar
Thanked: 193 Times
some people asked me about the fuse iam using.
this is the fuse folder iam using after properly soldering the wire to In and Out points and then wrapped nicely with Electrical Tape.
This holds the Fuse for 1AMP. which is sufficient for Driving L.E.D. based lights.
Changing Fuse will not require any Re-soldering as it twist opens.
Old 10th July 2009, 22:00   #7
Infractions: 0/1 (10)
Attachment 153518
Attachment 153519
Sigh! The darkspots in my santro! Gphk, why aren't you in chandigarh?! I'd have stolen the console from your car then.
bharti22shresth is offline   Reply With Quote
Old 25th July 2009, 15:01   #8
ghpk's Avatar
Thanked: 193 Times
paa ji, aa jaon chandigarh, free installation assistance key liye.
anyway its quite easy to do, and best effects is when you place a transparent water glass on it.
Old 13th August 2009, 12:37   #9
wanderernomad's Avatar
Thanked: 804 Times
@ghpk: Next time you are in Delhi let me know. Would love to have your free assistance. I also want to ahve the LED lighting system at some vantage points in mt Marina to brighten up the interiors.
wanderernomad is offline   Reply With Quote
Old 13th August 2009, 20:33   #10
aa jao! More than welcome to some punjabi hospitality. Actually I also want to try it out.
Do you have some more of the "under the console pics". I mean it flipped over.
Old 15th August 2009, 04:57   #11
ghpk's Avatar
Thanked: 193 Times
wanderernomad i have to come delhi, but it keeps on postponing
seems I am gonna earn a few friends with this LED craze.
bharti22shresth khoob jameygi jab mil baithengey 2 punjabi.
anyway will open it for you and take the snaps, can you tell here or PM what exactly you wish to look into.
and lastly, Here's another LED stuff i added, the strips are not centered properly, will adjust when i have fevi kwik handy.
switch for this one is also in the coin groves in the cup holder/gear console.
Blue L.E.D Cup, Coin holder Light, with 2 Extended/Adjustable L.E.D. Lights-bumper_led.jpg
Old 15th August 2009, 10:33   #12
@gphk-Though, I'm not a punjabi, but "spirit to punjabiyon ki hai" . Just two close up pictures of the encircled areas.
Thanks in advance.
Blue L.E.D Cup, Coin holder Light, with 2 Extended/Adjustable L.E.D. Lights-edited.jpg
Old 15th August 2009, 17:35   #13
ghpk's Avatar
Thanked: 193 Times
bharti22shresth, will take the pic tomorrow as my digi-cam is with a friend and if i use the phone cam it would not be much clear.
anyway the loose wires you notice is running between LED's two on front cup holders, and one round coin box which is under the Handbrake.
Old 22nd December 2009, 10:19   #14
pragya's Avatar
Hi GHPK
Can you tell me which LED did you used.
I tried this thing with my car cigarette lighter to give it blue glow but the LED blew.
Can you tell what wattage LED to used and do i need to connect it directly or put some resistance etc.
pragya is offline   Reply With Quote
Old 23rd December 2009, 18:50   #15
adishenoy's Avatar
Originally Posted by pragya View Post
Hi GHPK
Yes you need to use a resistance because the LED has a lower voltage requirement (the voltage requirement depends on colour). The car cigarette lighter produces 12V ( a blue led requires 4V ).
Use this LED Calculator.
adishenoy is offline   Reply With Quote
VW Vento Cup for 2015! Replaces the Polo Cup S2!!! Indian Motorsport 7 4th August 2015 16:29
Coin Test for Tyre Wear checking mithun Tyre & Alloy wheel Section 17 29th July 2015 13:07
Coin and Currency Collectors shivshanker Shifting gears 10 30th May 2014 14:56
DIY SOS: Extra coffee cup holder in the Ritz akshay DIY - Do it yourself 14 10th November 2011 08:27
Baleno cup holder lid nisam76 Modifications & Accessories 12 18th January 2010 07:46
