Old 28th June 2009, 21:23   #1
GRV
Thanked: 9 Times
Default My Grand Vitara Veering towards Left
Hi
For last 24 hrs , I have noticed that my car starts moving to the left when I take my hands off the steering.
Do I need Wheel Alignment ?
Till 2 days back this problem was not there. I had to start my car once by desi method of push by three people with neutral gear and suddenly moving to 2nd gear (because battery was down).
Could this be reason for current veering towards left ?
Thanks for help
GRV
GRV is offline   Reply With Quote
Old 28th June 2009, 21:37   #2
abhinav.gupta88's Avatar
Thanked: 310 Times
Yes, its most probably the Wheel Alignment.
Get it done before there is uneven wear on the tyres.
That should basically solve your Going Left problem.
Old 28th June 2009, 22:36   #3
.anshuman's Avatar
Thanked: 9,159 Times
Most basic reason can be too much difference in tire pressure.
Old 4th July 2009, 19:58   #4
GRV
Thanked: 9 Times
Hi
I have got wheel alignment done (after ensuring proper tyre pressure) but still the problem exits. I opted for road side machine to save money (Rs. 350 vs. 600 estimate given by PASCO maruti dealer) . They changed front tyres but still no improvement
Surprisingly the shop did not have specification in their alignment machine for Grand Vitara 2007 model. They used specification for 1.6 ltr suzuki model 1987-93.
It looks maintaining this car will be tough going forward.
GRV
Old 4th July 2009, 22:30   #5
gpa
gpa's Avatar
Thanked: 282 Times
Why don't you take the car to a reputed dealer and get the wheels aligned? From what you have stated, it is evident that this is a case of a problem with the alignment. The guy who aligned your wheels not havin the setting for the GV and using an older setting could have made matters worse. Just make sure you get it checked at another wheel alignment dealer.
Old 4th July 2009, 22:44   #6
Thanked: 25 Times
Please get the vehicle aligned using proper setting.
btw also check the road. I have myself also seen that problem and realised that the road is angled to the left to avoid water clogging. The roads are made at steep angles at some places. :(
supercars is offline   Reply With Quote
Old 5th July 2009, 11:18   #7
.anshuman's Avatar
If you have got it aligned using older car's settings that is the reason,go to some reputed tire shop they might have the settings for new GV.
Swift Diesel Steers towards the left. tush Technical Stuff 132 29th September 2010 10:22
New Grand Vitara Coming soon.. (2007 model) sajo The Indian Car Scene 30 16th December 2008 17:00
Grand Vitara ..how good is it? sunith SUVs, MUVs & 4x4s 12 24th April 2006 10:50
New Suzuki Grand Vitara in US sumitsingh The International Automotive Scene 2 22nd September 2005 09:24
