Old 3rd July 2009, 16:10   #1
kapilsharma80's Avatar
Thanked: 28 Times
Default Palio 1.6 ac compressor gone kaput
Hi guys,
My friends palio 1.6 has done about 85K kms. it is 8 years old.
Recently there was a fall in cooling capacity. got it checked by dealership and other roadside mechanics. The verdict was same-- replace the compressor.
The oem is worth appriximately 24k, which is not available at CHANDIGARH.
can you please share your inputs.
We have got the ac gas / pressure checked. the blower is also good.
Also, can the compressor be replaced with any other brand (Sanden). to best of my knowledge palio 1.6 is supplied with Denso kit.
kapilsharma80 is offline   Reply With Quote
Old 3rd July 2009, 16:21   #2
planet_rocker's Avatar
Thanked: 368 Times
wouldn't it be better if he gets a new OE compressor source through the FIAT a.s.s. from Mumbai / Pune / Delhi? or can he source an used compressor from a local market?
planet_rocker is offline   Reply With Quote
Old 3rd July 2009, 16:28   #3
Ravveendrra's Avatar
Thanked: 406 Times
Originally Posted by kapilsharma80 View Post
Hi guys,
Yes, the 1.6 normally comes with a Denso compressor.
I have heard another owner of a 1.6 mention that he fitted a Sanden in his car. He did mention that the Sanden's mounting are different from the OE mountings and, he had to have the mountings etc. for the Sanden fabricated.
It might therefore be better to take Planet Rocker's advice and place an order for an OE piece via Fiat A.S.C.
Cheers,
Ravveendrra is offline   Reply With Quote
Old 3rd July 2009, 16:33   #4
Thanked: 28 Times
thanks guys! i also considered installing a used compressor but couldn't find one. i am sure the compressor cant be repaired. Does Denso has service centres across cities like TVS Lucas??
Ac compressor gone bust? tsk1979 Technical Stuff 108 9th February 2017 00:13
Skoda Octavia RS 1.8 TPi Gearbox gone kaput @ 60,000 Kms!! nanu28 Technical Stuff 34 22nd March 2011 12:08
Alto clutch gone kaput @ 13000 km / 1 year burnt. Technical Stuff 11 9th December 2010 22:57
Audio system/roof light/door warning-Gone kaput together. akshay_b Technical Stuff 15 16th July 2009 11:36
Is my headlight relay gone Kaput? WAGON_R Technical Stuff 9 3rd March 2009 11:36
