Old 9th July 2009, 13:31   #16
vikram_d's Avatar
Thanked: 940 Times
This looks like a problem with the Idle Air Control valve (IAC). Happened on my car too immediately after throttle body cleaning. The problem on my car was that the IAC valve screws had not been tightened properly and the IAC eventually came loose. The car would idle at 2400 rpm.
In your case I think the IAC valve got stuck due to some debris in it. And once the debris got flushed out it became normal. Get the throttle body cleaned thoroughly and that should solve your problem.
I do not think that it is an electrical problemor an ECU problem.
Old 9th July 2009, 15:12   #17
menonrajesh's Avatar
Thanks Vikram! It sounds to me quite convincing and so similar because I had got the throttle body cleaned very recently. I will move this point to the top in my checklist for MASS.
Edit : Just spoke to Lokesh at Surakshaa. He had checked IAC thouroughly and the scanning tool also returned no issues. IAC motor was not weak too to fail to get detected in the scanning tool. In any case, I will get the throttle body checked once I visit them.
menonrajesh is offline   Reply With Quote
Radiator Fan keeps running, even after the ignition is off! newcoolgadgets Technical Stuff 48 31st March 2018 19:02
Radiator fan conked off in my Fabia! mayank123 Technical Stuff 13 21st November 2014 08:48
Radiator Fan never turns off! aargee Technical Stuff 11 13th November 2012 11:49
Strange problem with Petra - Radiator fan jraj Technical Stuff 8 24th August 2008 14:00
Radiator Fan Blues tsk1979 Technical Stuff 14 29th October 2007 17:31
