Old 17th June 2005, 22:06   #1
Default Cng For Diesel Safari???
Hi Guys, Got An 99 Model Safari Done 80k Kms. Was Just Wondering To Convert In2 A Cng.
What Will Be The Changes, What Will Be The Power Like??
Any Heating Problem With Cng??
Will The Engine Make Sme Noise As Diesel???
Amit
shahmotors is offline   Reply With Quote
Old 17th June 2005, 22:44   #2
Mpower's Avatar
Thanked: 1,687 Times
Check with the taxiwalls. They use Diesel-CNG on their 138Ds.
Old 17th June 2005, 23:03   #3
Thanked: 103,618 Times
Dude,
A Safari engine with 80,000 kms is already on its last legs. Why would you want to run it on CNG? You really arent going to save much and the entire conversion will most probably turn into a disaster. Yes, the engine will overheat once running on CNG.
Old 17th June 2005, 23:09   #4
highwayblaze's Avatar
nice ones. just thought that sounded so funny and true at the same time
highwayblaze is offline   Reply With Quote
CNG Oil Change - Regular or any CNG specials? panky12345 Technical Stuff 5 20th May 2016 11:56
Wagon R LXI CNG Vs Wagon R VXI + CNG Kit ajay387 Hatchbacks 37 7th October 2013 22:54
Swift Lxi (CNG Fitted) vs Santro GLS (CNG) coolaxe Hatchbacks 18 28th June 2012 16:58
What to choose safari petrol or Safari diesel 2.2L 007 Bond SUVs, MUVs & 4x4s 22 31st August 2007 21:56
