Old 11th August 2010, 20:12   #46
pranavt's Avatar
Thanked: 274 Times
How much time does it take for the clutch to engage and disengage? This could be used for DIY paddle shifter mechanism that I have been thinking of
pranavt is online now   Reply With Quote
Old 11th August 2010, 21:01   #47
Thanked: 436 Times
Is it available in Kerala? The other 'Auto Clutch Systems' available in the market require the car to be taken to Bangalore for fitting as well as servicing.
The gear sticks of the ones I have seen over the internet have a button that needs to be pressed for changing gears. In this case, if the sensor really works (and if the system is reliable), it's convenient.
jinojohnt is offline   Reply With Quote
Old 11th August 2010, 21:50   #48
foby.sebastian's Avatar
Thanked: 1,105 Times
Yes it is available in Kerala now including the service.
The same company has also developed the paddle shifter, the auto pilot and the cruise control mechanisms.
Note from the Team-BHP Support Team : Please use "Multi Quote" option for quoting Multiple posts, instead of creating another back-to-back post.
Last edited by Technocrat : 11th August 2010 at 22:07. Reason: Please read the note in your post, thanks
foby.sebastian is offline   Reply With Quote
Old 11th August 2010, 22:06   #49
Technocrat's Avatar
Thanked: 2,589 Times
A review of the Auto Clutch was also posted by member tanwaramit, here is the link Auto Clutch Review
Old 11th August 2010, 22:25   #50
Default auto clutch in Kerala now
One of my pal Mr. Jose David have took the distribution of the automate , so no need to travel out side the state to fix and service it.
Mods revealing the number plate is not a big issue here access granted
He use his petrol innova fitted with a BRC gas kit for longer jouneries
Old 12th August 2010, 16:56   #51
Thanked: 436 Times
From the pictures posted, it is not very clear whether we need to press a 'button on the gear lever' to change gears. Their website mentions that you need to press the button.
Could you please confirm?
Old 12th August 2010, 17:03   #52
pranavt's Avatar
Thanked: 274 Times
Old 12th August 2010, 20:22   #53
When i had a try , I didnt felt any time lag
Old 18th August 2010, 17:13   #54
tanwaramit's Avatar
Thanked: 387 Times
Its the same product used by me for around 4 years before I removed it.
Reasons:
Very high failure rate
Lack of service
Lack of spare parts
Lack of knowledgable people to fix
Lack of support from Himanshu Chitnis - Importer based in Pune to close the issues (for product, spare parts etc)
More details on my thread at http://www.team-bhp.com/forum/access...ch-review.html
tanwaramit is offline   Reply With Quote
Old 22nd June 2018, 01:38   #55
AdityaDeane's Avatar
Thanked: 187 Times
Default Re: Auto Clutch???
Is Auto Clutch equivalent to the AMT transmission that gained popularity with Maruti Suzuki Celerio? If it is as helpful as an AMT, I guess it is a good option to buy a MT car and get this installed as not all cars come with AT options, a person may like features in a MT car and similar features may not be available the AMT version, e.g. Celerio AGS ZXi(O) misses out on so many good things in comparison with Celerio MT ZXi(O), at about the same 30K odd, you can buy a MT Celerio and convert it to AT and can then transfer this system to your other car when you plan to sell it off.
AdityaDeane is offline   (1) Thanks Reply With Quote
Old 22nd June 2018, 07:54   #56
condor's Avatar
Thanked: 4,907 Times
Originally Posted by AdityaDeane View Post
Is Auto Clutch equivalent to the AMT transmission that gained popularity with Maruti Suzuki Celerio? If it is as helpful as an AMT, I guess it is a good option to buy a MT car and get this installed as not all cars come with AT options.. .
Yes & No. Yes because you dont use the clutch. No, because you must still change gears.
With Auto-Clutch you just operate the gear level without using the clutch.
Old 22nd June 2018, 09:21   #57
Thanked: 187 Times
That I understand I saw the videos as well, but it's kind of when you override the AMT in Manual Mode, instead of pushing the gear lever forward or back to gear up or down, in this you slide and slot the gear where you want, and the actuator does the job of pressing the clutch for you (which is hidden in case of AMTs but visible here as there is no change in the 3 pedals). I believe it is good for newbies who have trouble learning how to start a car and the good thing is that it can still be used by us other folks in Manual mode at any time. When in bumper to bumper traffic, switch to Auto mode. When out on the highway, switch to manual cruising if required. And it also costs about 35K as much as a factory fitted AMT Car.
AdityaDeane is offline   Reply With Quote
Swift D-Clutch/Gear Problem : Competent Motors unable to solve the clutch shudder Eddy Technical Stuff 48 8th September 2013 23:03
Using clutch and designing clutch... The Wolf 4x4 Technical 55 9th May 2011 11:50
Problem with Clutch - Clutch cylinder replaced! Hats off to Talera Motors! Chevy_lover Technical Stuff 0 24th September 2008 14:13
Which is the right Sequence Clutch-Brake Or Brake-Clutch ankura12 Technical Stuff 2 9th July 2007 10:02
wet clutch vs dry clutch and slippers clutches devsus Motorbikes 7 16th May 2006 10:08
