Old 7th July 2009, 17:46   #1
Unhappy Ford Fiesta - Thump sound on braking
There appears to be a thump-thump sound coming in from the brakes on my Fiesta (2 years old, 16K). This is very prominent initially when the car starts but the sound goes down to a low level as the drive progresses.
I took it to the service station (Lathangi Ford, Bangalore) and the service folks told me that the the brake disc has worn down ("abnormally") but that should not be problem at all. Is this really true? This should be a cause for no concern? Frankly, the sound is disturbing me very much, since am used to nice the hum of the Fiesta and the thump comes in the way of enjoying that...
Krishna
calvinkrishy is offline   Reply With Quote
Old 7th July 2009, 18:27   #2
SS-Traveller's Avatar
Thanked: 11,626 Times
So my guess is you'd need to have the discs turned (polished and levelled), with a set of new brake pads. Shouldn't be too expensive, but then it's a Ford... But why the unusual wear? Due to heavy use, or a problem with the brake system? Please ask the A_S_S to check that too.
Old 7th July 2009, 18:59   #3
vnabhi's Avatar
Thanked: 1,311 Times
2 years and 16 K is too darn short for a change of brakes, unless you've been riding on them literally. Please ask the service advisor to check them up. Is it an ABS-equipped car---not that it should make any difference.
Old 7th July 2009, 21:34   #4
ariendj's Avatar
Thanked: 83 Times
i also think its a bit too early for brake pad changes!!
btw,is your car still under warranty!!
ariendj is offline   Reply With Quote
Old 21st July 2009, 13:37   #5
As per the service advisor the brakes are fine and the sound should not be a cause of concern. Even I haven't observed any problem with the brakes as such all I am worried is that the sound could be a harbinger of something serious in the brakes.
The car is under extended warranty. I plan to take it to them and have it re-looked. What I am frustrated about is the guy's plan of action - replace the entire brake component but without saying anything clearly about the problem at hand (why did it happen?) He also went on to claim this happens in many Ford cars!!!
Old 21st July 2009, 22:22   #6
sbala's Avatar
Thanked: 158 Times
Sometimes i too get some sound (like the sound that comes when you drag any tables) when i apply brakes on the slopes. But otherwise - its absolutely fine...
sbala is offline   Reply With Quote
Old 21st July 2009, 22:50   #7
gpa
gpa's Avatar
Thanked: 282 Times
Brake pads are usually not covered under warranty.
The Thump, I always loved the most Ownership Review of Classic 350 traveloholic Motorbikes 31 14th February 2016 10:06
Not happy with thump effect need help viraj_s85 In-Car Entertainment 29 20th March 2010 03:27
More thump from AVL engine alpha1 Motorbikes 11 4th November 2008 12:13
Advice from Gurus - More thump from Sub manojgautham In-Car Entertainment 16 5th September 2008 10:04
