Old 7th July 2009, 21:47   #1
Default Synthetic Oil Grade for Palio
I have just left my palio for service and was surprised that the staff at Concorde, Bangalore indicated to me that they do not have synthetic oil. The service guy told me that he would be happy to change the same provided that I purchase and hand it over to them, since he told me that Fiat recommends only mineral oil.
I am a tad concerned, is this correct?
If not, which grade of oil needs to be used for the same and what is the quantity of the same to be used for a 1.2 petrol?
viana is offline   Reply With Quote
Old 7th July 2009, 22:09   #2
muralisk's Avatar
Thanked: 9 Times
I am not sure if there is any restriction on using synthetic oil. You can check with Shell gas stations as they do have synthetic oil. Check your owners manual for the quantity related details.
muralisk is offline   Reply With Quote
Old 7th July 2009, 22:11   #3
finneyp's Avatar
Thanked: 165 Times
Yes, Concorde is right, Fiat recommends mineral oil for Palio 1.2 routine service.
If you want to put Synthetic oil, you can buy Mobil1 / Shell Helix Ultra / Castrol Edge.
Palio 1.2 would require 3 lts. of engine oil.
finneyp is offline   Reply With Quote
Old 7th July 2009, 23:07   #4
Roy.S's Avatar
Thanked: 94 Times
How many kms does your car have on the odo?
I wonder why fiat recommends only mineral? I used Mobil1 5w50 on my last oil change (swift vxi) a week back and am very happy with it. I think the same grade would be fine for your Palio.
Also, it would probably be a good idea to do an engine flush.
Roy.S is online now   Reply With Quote
Old 8th July 2009, 09:40   #5
gemithomas's Avatar
Thanked: 136 Times
why dont you enquire if you could use the oil that is recommended for the linea. I think its called selina.
The OEM grade should be 15W40.
ARTICLE: Synthetic oil vs Mineral oil GTO On modifying a car 4837 23rd January 2018 17:45
SAE 50 grade oil for Yezdi & Land Rover Sudarshan Technical Stuff 7 24th June 2011 18:45
What grade engine oil?? jigarmuni Technical Stuff 45 24th September 2008 09:36
