Old 5th August 2009, 10:09   #16
MindSpeeDs's Avatar
Thanked: 79 Times
Apologies for not updating this thread earlier.
Strange things happen! Existing water pump is absolutely fine, removed the thermostat valve
(was in bad shape). Issue solved!
No clue as to why the increase in RPM was working though.
MindSpeeDs is offline   Reply With Quote
Old 5th August 2009, 11:59   #17
tsk1979's Avatar
Thanked: 15,639 Times
Ahh the valve.
Its obvious. The valve was partially clogged.
When you rev the engine the water pump pressure also increases, hence flow was okay. so with clogged valves which open partially, many times water flow is not optimal at low rpms.
Engine Overheating Issue cnaganathan Technical Stuff 66 15th January 2013 13:07
Very Strange Overheating Issue, Please Help johnruben Technical Stuff 34 3rd December 2010 02:22
Major error in Autocar March issue & Overdrive April issue as well Guna Shifting gears 20 11th May 2010 11:15
Performance issue for Lancer Diesel bibin999 Modifications & Accessories 2 21st July 2008 17:41
Engine Idling Issue 2fast4u Technical Stuff 10 5th February 2007 12:55
