Old 13th July 2009, 22:28   #1
gemithomas's Avatar
Thanked: 138 Times
Default speedo not working once in a while
the speedo, odo and trip meter does not work once in a while. what could be the reason.
Old 13th July 2009, 22:54   #2
hvkumar's Avatar
Thanked: 3,365 Times
Check the speedo sensor and replace it. Is the odometer also simultaneously working erratically - recording too fast, too slow or not at all?
hvkumar is offline   Reply With Quote
Old 13th July 2009, 23:31   #3
nitrous's Avatar
Thanked: 285 Times
Check speedometer cable. Replace if necessary.
Old 14th July 2009, 08:44   #4
gemithomas's Avatar
Thanked: 138 Times
I think the odo is behaving as per the behaviour of the speedo. It does not move when ever i see the speedo lying at zero while the car is moving at higher speeds.
Old 14th July 2009, 13:18   #5
gpa
gpa's Avatar
Thanked: 282 Times
Worn out teeth of the speedometer cable is what is causing this. Replacement is the only way to go.
Old 14th July 2009, 13:30   #6
Pashin's Avatar
Thanked: 31 Times
Hi Gemi,
The Palio has a speedo sensor maybe thats what is the problem, or might be the circuit of the speedo meter
Pashin is offline   Reply With Quote
Old 15th July 2009, 09:43   #7
gemithomas's Avatar
Thanked: 138 Times
is the odometer movement relative to the speedometer or even the speedo sensor? never thought it would be like that.
Old 16th July 2009, 21:10   #8
nitrous's Avatar
Thanked: 285 Times
Thats why I've bolded 'Replace'. There's always a 1% chance of something else malfunctioning.
Do you raise the height of your laptop while working? NK@Hyd Shifting gears 40 11th April 2013 19:59
How I almost bought a car, not once but thrice!! sachinj12 Shifting gears 13 27th November 2009 21:26
my speedo ended !!!- zen needle crosses last point on speedo speed0mania Street Experiences 81 11th August 2006 12:22
mp3 cd not working in player a4_attitude In-Car Entertainment 2 15th September 2005 23:04
palio 1.2: starter not working properly... amitverma Technical Stuff 14 3rd April 2005 00:34
