Old 14th July 2009, 11:16   #1
Thanked: 955 Times
Default New Honda City (NHC - August 2004, 68,000KM) - Engine Shakes On Startup - Need Advice
Hi, My NHC (August 2004) has done 68,000KM and a used car dealer while evaluating the car said engine is vibrating more than normal on start-up so checked out myself - it really does and after a careful look - I saw that a mount on the driver's side (that directly connects the engine to the frame) as well as a lower mount on the co-passenger side (that connects the gearbox to the frame) are showing cracks and do vibrate like hell momentarily on startup.
So I am going to get all the engine mounts replaced at Deccan Honda.
Any idea how much time and money this will cost?
How many mounts in total do I have?
Is 68,000KM really the average life of the engine mounts? I thought they would live a little longer...my Tucson is still going strong at 74000KM!
Advice please...
anandpadhye is offline   Reply With Quote
Old 14th July 2009, 13:00   #2
Thanked: 955 Times
Ok...here is the estimate from Deccan Honda:
MTG RUB ASSY,TRNS 50805-SAA-013 2,798.40 1 12.5% 2.3% 3,210.87
(LQ)INS RUB,MTG RR (M 50810-SEL-T01 1,407.83 1 12.5% 2.3% 1,616.86
(LQ)BRKT,SIDE MT 50823-SEL-T01 1,901.74 1 12.5% 2.3% 2,184.58
MTG RUB ASSY 50826-SEL-E01 4,673.04 1 12.5% 2.3% 5,368.18
What say?
Old 14th July 2009, 13:04   #3
gpa
gpa's Avatar
Thanked: 273 Times
Can you please remove the formatting of the text before you post. The chunk of text is totally unreadable
gpa is online now   Reply With Quote
Old 14th July 2009, 14:04   #4
Thanked: 955 Times
Already edited...looks like our posts crossed each other on wire.
OK, from another thread, i read that if the engine vibrates only on start-up, it could be related to some front member alignment....is that true?
Hi Mods, can you please change the title to:
Thanks!
Old 14th July 2009, 18:22   #5
Thanked: 89,133 Times
Used car dealers will always find excuses to pay you less money, I suggest getting an independent evaluation. I'd be very surprised if your mounts have gone bad. The ones on my OHC Vtec (at 70,000 kms) are still healthy.
Did the authorised service station confirm that you need to change your engine mounts?
Old 14th July 2009, 19:33   #6
f1fan's Avatar
Thanked: 41 Times
+1 to that. Used car dealers are notorious at finding faults so that if you trade, they can pay you less.
Pls show the car to an authorized dealer and get a second opinion.
f1fan is offline   Reply With Quote
Old 14th July 2009, 21:10   #7
Thanked: 955 Times
Thanks GTO and f1fan.
Much appreciated.
Will take it to Deccan Honda and confirm.
Old 15th July 2009, 11:53   #8
yes, this is a fit case of problem with engine mounts. Usually, they should last beyond 150,000 kms. But in your case its unusual that it had such a short span! Please get it replaces asap as this could affect the stability of the car at higher speeds incase one of them breakout completely. Should cost you around 10K. Its better to stick to the authorised dealer for replacement of the Mounts.
sandeep.mishra is offline   Reply With Quote
Old 18th December 2009, 20:50   #9
mdesai_1981's Avatar
hi guys i have a 2008 NHC with 13500kms on the ODO. now just a few days back i noticed a vibration on startup dont know how but the car runs smoothly and there is no abnormality otherwise. it just happens on starting the car.
one small thing can rats chew the engine mountings?
waht could be the possible expense i should expect if i have to change the engine mounts?if need be
mdesai_1981 is offline   Reply With Quote
Old 19th December 2009, 01:02   #10
Thanked: 955 Times
well...there are 4 mounts they all cost different. Please see my post above.
BTW, friends, I realised that the info I posted about how the problem was resolved seems to have not been updated (may be the server died on me and I did not notice then...)
In my case, the rear engine mount (the cheapest @Rs.800) was replaced. They lifted the car and inspected all the mounts...
I was wondering if I should anyway get all 4 replaced to avoid periodic service trips for this/similar issue, to which they said - all 4 were equally new to start with because they came with the car, yet one died early...so replacing 4 simultaneously may not assure that they would wear equally...
That was reasonable...
Help needed : Toyota Corolla 2004 Random Startup problem singh.amrit Technical Stuff 15 21st December 2016 12:45
Hyundai Santro Xing: Engine shakes and stalls ricky_speed Technical Stuff 11 13th September 2013 09:09
NHC Suspension at 62,000KM - Want a better alternative to the OEM Honda suspension anandpadhye Technical Stuff 15 13th September 2008 18:56
The Civic Effect : Market shakes up GTO The Indian Car Scene 97 6th October 2006 17:00
City Driving NHC/NHC-CVT or Vtec Rahulk76 Sedans 7 27th April 2006 16:51
