Old 8th June 2016, 12:32   #511
90Horses's Avatar
Thanked: 37 Times
Default Re: Some quality niggles & Issues in Fiat Punto
Originally Posted by nkrishnap View Post
Get the engine C mount checked and also the A and B mounts, my guess is its gone. Replace it and it should be fine.
Also on the rpm jumping issues, a week alternator can cause this. Get that checked too.
Thanks I will get the mounts checked. How an alternator could lead to the rpm jump issue?
90Horses is offline   Reply With Quote
Old 8th June 2016, 12:34   #512
nkrishnap's Avatar
Thanked: 4,162 Times
I am still finding the reason why it would, but it does. A faulty alternator was causing the rough and unstable idling on my friend's Linea. Once the alternator was fixed it was sorted out.
nkrishnap is offline   (1) Thanks Reply With Quote
Old 8th June 2016, 19:00   #513
Thanked: 29 Times
Originally Posted by BulZire View Post
Thanks much for the reference, I will defintely get in touch with them. The SE in Vecto is Prem.
I still remember him. AVOID PREM FROM VECTO MOTORS AT ANY COST..dont let him come near your car. I have had bad experiences with him.
1. I showed him uneven wear on one of the rear tyre..for which he told me that the suspension needs to be replaced..and will cost 18K. He showed my few photos in his mobile telling that he shot them when the care was jacked. it was some picture of a cover for the suspension spring..any common man would fall prey to his argument and agree with him.
when I got my car checked with other knows mechanic. he told me that the suspension is alright..went ahead and replaced it with a spare tyre..till now, I have done 5K on it and i do not see uneven wear anymore..it was a tyre fault..not suspension.
2. He called me and told me that the brake pads may last another 1K, so i replaced them. when I checked them they still have half life left. My car had done just 28K Kms.
3. He had few double billing like Brake cleaning = 400+ brake pad installation = 500+
I left the service station in shock, the I need to spend 18K on suspension..If I meet him again, he is going to get a nice one from me..
sad:) is offline   (1) Thanks Reply With Quote
Old 8th June 2016, 19:15   #514
Thanked: 29 Times
Hey guys, i need your advice. Recently i have changed my tyres to yoko earth1 with stock profile 195/60/15. After tyre change i feel some sort of shake while i drive in 2nd or 3rd staring from 12krpm to 18k rpm. This shake can be felt inside the car. Initially I thought it was balancing or alignment issue, have done a/b thrice and checked for alloy bend but everything reg tyres was fine.
After repeated tests I figured out, the wobble/shake happens only if the engine rpm is b/w 12-18k rpm and gear is in 2nd or 3rd.
I'm losing peace of mind and I am unable to enjoy my new set of tyres, I request you guys to help me with this issue.
Sai
One of my friend had a similar problem. He was unable to find out the reason for this for a long time and was annoying..you feel it only on a particular speed. he almost concluded that the axle may be bend and he needs to replace it. He raised this issue with tyre manyfacturer that this probelm has started only after he installed new tyre..finally it was concluded the tyre had a weak patch which was causing this problem. When you are at a particular speed, the timing is such that the effect of this weak tyre is clearly noticeable (kind of resonance). his faulty tyre was replaced under warranty.
Please check for any patch wear on your tyre..any particular are on the tyre wearing fast or showing signs of weakness.
Other option, give a try replacing tyre one by one with a spare one. I you see any good results, then you know that the tyre is culprit.
sad:) is offline   Reply With Quote
Old 24th June 2016, 14:07   #515
Thanked: 80 Times
Recently I bought an used Grande Punto 1.4 8v 77PS petrol in Germany which was already driven for 145000 kms.
Following are the niggles which found in the used car:
1. Rear parcel tray clips got broken. Bought it from eBay and fixed it. Cost: 10
2. Cover for small fuse box on top of the battery is not there. Bought it from eBay and fixed. Cost: 22
2. AC was not working at all. Took it to the workshop and it seems AC refrigerant is empty. Refilled it in the workshop. Cost: 50
3. AC cooling is very minimal even if outside temperature is 25 degC. I suspected that the pollen filter might be blocked. So when I tried to open it I found out that the clip on the top of the black filter cover is broken and the cover is hanging because of which the cold air is leaking there and hence less cooling through the vents. Now ordered the cover through a Fiat dealer. It is not available online. Cost: 22
I find that these small plastic parts are very difficult to buy from internet and its very expensive if ordered through dealer.
gopi_rm is offline   Reply With Quote
Old 24th June 2016, 22:59   #516
Thanked: 80 Times
Hi Guys,
As I mentioned in my previous post, the cover of the pollen filter is broken and hanging. When AC is switched on, the coldness of the air coming out of the vents is very less and hence if I set the blower to full speed then air is neither cold nor hot.
Is it an issue due to the hanging pollen filter cover or due to any leak in the AC circuit?
Please give your opinion.
Old 11th October 2016, 16:39   #517
BulZire's Avatar
Thanked: 132 Times
Guys, need help in diagnoising a issue in Blue&Me.
Since morning, the USB is not getting detected. Also, there is no operation happening or nothing is displayed in console when i click main menu button in steering.
But my phone is paired and receive calls without issue. I don't see any problem in other steering mounted controls.
Please suggest if there is workaround i can try myself to fix this before taking to FASS.
BulZire is offline   Reply With Quote
Old 14th October 2016, 11:22   #518
sandeepmohan's Avatar
Thanked: 1,659 Times
It is possible that the usb device has failed. Check if Blue N me controls work by unplugging the drive. Do so after shutting down the car, unplugging the device and re starting the engine.
Plug the usb device on a computer to check that it works. Check if you read and play back content from your computer.
If the usb drive is found to be working on your computer, then the last option is to disconnect the negative terminal on the battery (no tools required), wait for fifteen minutes and reconnect. You will have to set the date and time again. Now check if Blue N Me works with the drive plugged in.
I have had a few instances of Blue N Me acting up. Disconnecting the negative terminal on the battery solved all problems related to Blue N Me.
sandeepmohan is offline   (1) Thanks Reply With Quote
Old 17th October 2016, 15:21   #519
BulZire's Avatar
Thanked: 132 Times
I tried all that you have suggested except disconnecting the negative terminal on the battery. Nothing helped and took the car to Vecto on saturday.
They did run the diagnostics and reset Blue&Me software. All fine now and was Charged 400Rs for this.
Later i felt that i should have tried disconnecting the battery also.I will keep this mind if Blue&Me shows some problem in future.
Old 15th January 2017, 09:34   #520
blackstallion76's Avatar
Thanked: 11 Times
Recently, I am experiencing strange accelaration surges in 3rd and 4th gears. Plus the kmph guage has stopped working. But, fuel guage/rpm guage/temp are all working fine.
When i slot the gear to 3rd/4th gears the engine has lot of torque hovering 1500rpm to 3000rpm. Without pressing accelarator the car is pushed itself for brief moment. And it surges pretty fast and hard to control.
Any suggestions please.
blackstallion76 is offline   Reply With Quote
Old 14th April 2017, 16:43   #521
90Horses's Avatar
Thanked: 37 Times
Hi Guys, one quick suggestion. In My punto 90hp, there's a oil kind of residue left on the vaccum pump. It comes back in a weeks time after cleaning. I have seen this happening from 2 years now.
Last time when I was at Aadya Fiat Bangalore, sa Mr Raghuram said, this is unusual and he doesn't see it in all 90hp engines. I was worried, they have tightened the nuts of the vaccum pump and said, this should fix it.
But after a week oil residue started to come back, now I am worried.
Do all your 90hp engine vaccum pump have an oil residue over it? It's not like a dripping oil leak, its like, dust settled on oil kind.
Images were 180deg rotated while upload, pls have a look.
Sai
Old 26th July 2017, 09:33   #522
lurker's Avatar
Thanked: 641 Times
guys, I have a query. While driving I make a stop to pick up a friend and need to open the rear door. How do I unlock the rear door from inside from drivers seat ?
do I open rear door from the unlock on the key fob ?
Is there any other option ?
lurker is offline   Reply With Quote
Old 26th July 2017, 09:36   #523
lapis_lazuli's Avatar
Thanked: 429 Times
No. Just partially unlatch your(driver) door lock. Say, just about half the travel required for full open. It will unlock all doors, including drivers.
lapis_lazuli is offline   Reply With Quote
Old 26th July 2017, 09:47   #524
lurker's Avatar
Thanked: 641 Times
that will open my driver door no ? Then I need to close the driver door by opening and shutting it. I have not been able to make this partial unlatch without the need to shut driver door again.
What am I missing here ?
Old 26th July 2017, 09:52   #525
Arjun Reddy's Avatar
Thanked: 1,109 Times
Partial pull on the door lever will unlock all doors. You can then press the same lever to lock all doors. You don't have to physically open and shut your door.
Arjun Reddy is offline   (1) Thanks Reply With Quote
Black Punto MJD - 30400 KM Completed - Some issues ~~VinZ~~ Long-Term Ownership Reviews 9 21st April 2011 18:37
Swift VDI+ABS or Fiat Punto MJD or New Fabia 1.2 Diesel. Edit- Booked Fiat Punto MJD magnanimousdude Hatchbacks 59 27th October 2010 13:18
