Old 28th July 2009, 10:08   #16
gpa
gpa's Avatar
Thanked: 282 Times
Originally Posted by glenn View Post
I think there is technique issue I do face the same issue when especially go down on gears from 3rd to second or 4th to 3rd
Also by doing this part like what Mithun expressed will the Gear Box get worn out?
glenn,
If you are new to driving, then I suggest you practice shifting gears with the engine switched off to get a feeling how the lever moves through the gate. When driving, do not shift in a hurry as that will lead to you missing gears (shifting into 2'nd instead of 4'th gear). You need to shift gears in one fluid seamless motion. The jerk that you experience is not because of not shifting correctly but rather letting go of the clutch abruptly.
The gearbox and engine will be put under undue strain when you shift into lower gears at higher rpm. Almost all cars come with synchromesh gearboxes that make shifting a breeze. A little bit of practice and you will be shifting like a pro.
Cheers,
gpa
Old 28th July 2009, 18:13   #17
Awaiting Email Confirmation
Thanks GPA
glenn is offline   Reply With Quote
Figo TDCi: Dies occasionally while downshifting! Solved: Updated firmware by Ford jayded Technical Stuff 606 19th December 2017 10:09
MAN TGA 430 - Engine won't rev in 5th gear paw1 Commercial Vehicles 4 16th July 2014 09:22
Ever thought of downshifting? From big car to small car? throttleking The Indian Car Scene 114 22nd December 2011 10:01
My Linea jerks while downshifting the car DownTheLine Technical Stuff 38 24th November 2009 22:31
Judder while downshifting (Safari 2.2) rb2399 Technical Stuff 8 15th May 2008 00:44
