Old 17th July 2009, 09:46   #1
bantejas's Avatar
Thanked: 29 Times
Default Tata Safari 2.2vtt: Theorectical and observed speed/RPM
Hello all,
Can some one please tell me the theoretical and observed RPMs for speeds
60 in 4th Gear
80 in 5th Gear
100 in 5th Gear
120 in 5th Gear
140 in 5th Gear
in 2.2vtt?
Thanks,
Tejas
bantejas is offline   Reply With Quote
Old 29th July 2009, 11:13   #2
athalaga's Avatar
Thanked: 18 Times
Needed some info for this for me to do this. Ive outlined the calculation so you can do this by yourself
first find your wheel dia and then calculate your wheel rpm.
Say you want the engine rpm for 100kmph in 5th gear.
Convert 100kmph to m/s by multiplying by 10/36
then your 1000/36=3.14*wheel dia in meters*wheel rpm/60.
You can calculate your engine rpm by multiplying your wheel rpm by your overall gear ratio in 5th gear.
Hope this helps.
athalaga is offline   Reply With Quote
Old 29th July 2009, 14:00   #3
jkdas's Avatar
Thanked: 1,436 Times
140 @ 4k in 4th gear.
Calc says I am wrong; speedo err?
Old 29th July 2009, 14:44   #4
athalaga's Avatar
Thanked: 18 Times
Must be the calc is right AFAIK
New Beast Master (Safari 2.2VTT 4x2) wheelsNsqueals Test-Drives & Initial Ownership Reports 44 5th April 2010 12:50
How I decided on Safari 2.2VTT bkishore_77 Test-Drives & Initial Ownership Reports 24 20th August 2009 17:49
Turbocharger failure in new safari 2.2VTT(Edit: Solved; only a cracked rubber tubing) DDDHRUV Technical Stuff 104 11th May 2008 22:36
Tata Safari Dicor 2.2VTT Cycus Grey LX avanishphatak Test-Drives & Initial Ownership Reports 40 11th May 2008 17:36
Tata Safari 2.2VTT - Change in prices? itwasntme The Indian Car Scene 16 23rd January 2008 18:37
