Old 17th July 2009, 20:51   #1
Default Honda Civic dashboard rattles
I get some sort of very low rattling (sounds tic tic) noise from the dashboard of my Civic, which about 10k old. Its not continues, but get when you really runs over a scratchy road. Initially I thought its the tilt steering rubbing against some plastics, but its not. Has anyone observed this before. ?
swageo is offline   Reply With Quote
Old 17th July 2009, 21:01   #2
AbhiJ's Avatar
Thanked: 537 Times
Did you have any ICE installation done in the car?
AbhiJ is online now   Reply With Quote
Old 18th July 2009, 07:33   #3
Nothing.. Its as original as possible.
Old 18th July 2009, 11:51   #4
ImmortalZ's Avatar
Thanked: 312 Times
Get your steering column checked. I had a similar problem and it was the steering column cover (behind the wheel - it is the shell through which the stalks come out) plastic rubbing against something else. Very hard to reproduce, but very annoying indeed.
I have a similar rattle in my rear driver side door which started after the pads were removed for sunfilm installation. I plan to do a full ICE install with serious damping some time in the future, so I'm leaving it alone till then. It only surfaces when I'm a scratchy road as yours.
Old 20th July 2009, 19:44   #5
Too feels so. I am scared to attempt it myself, as airbag is housed on the steering.. I will get it checked on next service.
I too got similar rattle from rear portion of driver side door. It stops if you push the door.. so looks like something to do with the rubber/pads.
Looks like our cars are siblings
Honda Jazz DIY: Reducing rattles and custom lighting for the cabin & boot naikameya DIY - Do it yourself 19 7th December 2017 01:28
Attn i20 Owners: Good News | Hyundai's Solution for AC and Rattles tsk13 The Indian Car Scene 143 28th May 2013 13:21
Honda City Vs Honda Civic E Vs Honda Civic V (pre-owned) drkunaldas Sedans 4 31st October 2010 18:07
800 steering rattles sumeethaldankar Technical Stuff 9 2nd October 2010 21:35
If I want to change Vista Dashboard to Manza dashboard: A Discussion sushantr5 Modifications & Accessories 14 13th July 2010 12:08
