Old 18th July 2009, 18:31   #1
Default Zen throwing off coolant
Guys,
First time in the my history of driving a 99 Zen with 146000 kms tracked, I faced an issue while taking her out.
The problem:
I drove for about 14 kms with full ac. Park the car and move out to buy some things while my wife is in the car with AC on. When I return after 5-6 minutes, i see all coolant spread on the road beneath the car. Wife had switched off the car as some passerby indicated the coolant spread. I checked the temperature gauge and it was HIGH. Waited for about 10 minutes and arranged for some water. Opened the radiator, it was fuming and slowly pored water inside. Also the side plastic tank which stores the coolant / water was boiling. I drove back slowly as soon as the temp gaurge was back to normal and had to stop once in 14 kms of driving with no ac and bumper to bumper traffic.
Now, what is the root cause of this?
  • The radiator?
  • AC?
  • Others??
Pls. advise.
Tarun
Tarun is offline   Reply With Quote
Old 18th July 2009, 19:19   #2
gpa
gpa's Avatar
Thanked: 273 Times
Tarun,
It looks like your car's cooling system was not able to handle the extra load thrown at it by the a/c which is why, it started to overheat when you left it idling with the a/c switched on.
Do not pour cold water or coolant directly into the radiator when you find the coolant bubbling as it will lead to thermal shock and a blown head gasket. Wait for atleast 30 to 45 minutes for the system to cool after you open the radiator cap and then pour in the coolant/water.
Ask your sevice station to do a thorough check of the car's cooling system as you have clocked some serious miles on it. It could just be a block in the system that led to this one of incidednt that you mentioned.
Also make a mention for them to check the head gasket to see if its blown.
Cheers,
gpa
Old 18th July 2009, 21:53   #3
gpa, what could be failure in the cooling system? Do you have any idea how the cooling system works and what could be the potential failure points? Does it call for radiator change? or is it the spring which basically is there for the prevention of freezing the coolant in chilly conditions.
From some fellow maruti owners, I have heard the the spring does not operate after some period and they opt for removing the spring understanding that it is of no good use.
For some the radiator cleaning, wherein the option is to remove the internal springs and get it thoroughly cleaned. Though not sure if any of these is true.
Pardon me for asking so many questions.
The service owners usually talk of replacing this or that without proper diagnosis of the problem. So I basically wanted to avoid them taking me for a ride.
Thanks,
Tarun
Old 18th July 2009, 22:13   #4
gpa
gpa's Avatar
Thanked: 273 Times
The functioning of a cooling system in a car is rather simple. The most important function of the radiator is cool down the engine and getting rid off the heat by circulating water through the pipes (also referred to as jackets) located around the core operating parts of the engine.
I think what you are referring to is the car radiator thermostat. It is a temperature operated flow control valve specially designed to control the engine temperature. A car radiator thermostat consists of a seamless bellow as the sensing element. It works on the principle of partial vapour charge and could possibly be malfunctioning in your case considering the number of clicks on the odo.
Take your car to a service station and make mention to have the termostat valve checked.
Sometimes, scaling could have taken place inside the cooling jackets of the engine and all you would need is a radiator flush to set things right.
Hope this helps
Do keep us updated on what happens.
Cheers,
gpa
Old 20th July 2009, 21:20   #5
rajivanoj's Avatar
Thanked: 45 Times
check your radiator fan, whether it is working or not?
check with just running engine and look for gauge and fan, see whether the fan starts when the temperature reaches abnormal.
look for fan rotation, it shoud pull air from outside and throw inside. I had an bad experience with my esteem, when the electrician made the fan to rotate opposite side, and without knowing, i drove for about 25 kms and it started all boiling symptoms etc, and atlast the head gasket blown
rajivanoj is offline   Reply With Quote
Old 20th July 2009, 23:38   #6
vivekiny2k's Avatar
Thanked: 163 Times
the radiator cap is responsible for slowly releasing the coolant into the reservoir when under pressure. when cold, it pulls it back in system.
if the coolant is boiling out within minutes of starting, either it's too much of heat (less likely), or the cap valve has failed. change the radiator cap and see.
you can do it yourself. just twist, open, replace.
vivekiny2k is offline   Reply With Quote
Air-con: Center vents throwing out warmer air than side vents? 90Horses Technical Stuff 82 7th July 2015 16:03
Coolant spilling out of reservoir after I switch off the engine Irfanulla Technical Stuff 91 21st August 2014 21:37
Think before throwing waste! santhosh_kumard Shifting gears 0 5th November 2007 17:00
coolant guzzling Esteem chandan Technical Stuff 10 21st July 2005 12:28
