Old 28th July 2009, 16:32   #31
suman's Avatar
Thanked: 257 Times
Shashank, best to approach one of the Maruti workshops who have experience in outfitting Rally cars rather than a "hit & miss" DIY.....IMHO
Old 28th July 2009, 17:09   #32
Sideways's Avatar
Thanked: 18 Times
Hello Shashank, 2-3 mm aluminum chequered plate will do the job. Please try and have one made for the fuel tank also if there is enough space.
These plates will be available with most iron & Steel merchants and are generally used as flooring in buses and in the cargo bays of most LCV's.
Like Suman has suggested go to either a MASS or to a garage which prepares cars for the raid. There are plenty in Delhi.
Sideways is offline   Reply With Quote
Old 28th July 2009, 18:44   #33
Shashank.A's Avatar
Originally Posted by ashthedivx View Post
Are you sure you want to fit 4ft x 5ft sheet beneath the engine compartment, as per my understanding you do not need to cover completely it should be cover partially. .
that is what I will do. I am going to install the entire sheet, it will be cut and installed at strategic locations.
I have approached such workshops and have been quoted 12k and 20k respectively. rankly speaking as of now, I cannot afford that kind of money and even if I could, this is not justified for my use.
Shashank.A is offline   Reply With Quote
Old 29th July 2009, 14:14   #34
athalaga's Avatar
Thanked: 18 Times
If you cannot or dont want to change your timing, a simple upsizing your JET would work for you. Have fun
athalaga is offline   Reply With Quote
Old 29th July 2009, 19:05   #35
Shashank.A's Avatar
I will get it adjusted in Manali. I have been told that those mechanics have plenty of experience of "what car wants" in those roads.
Old 30th July 2009, 12:36   #36
suman's Avatar
Thanked: 257 Times
I told you to check with Lordofgondor, have you done that? He got his at Motorkraft (MASS with experience in rally car prep IIRC) at 7.5k
Old 30th July 2009, 18:47   #37
Shashank.A's Avatar
I have check with him, but it was only for engine sump. And secondly I looked under the body, and there are no grooves, so it means that they have drill some in the under body, on which I am not too keen.
Mission Leh! Four people, one scorpio and one helluva road trip! (Delhi-Leh Sep 2011) speed crusader Travelogues 15 11th July 2012 19:50
Ride to Leh - Preparing your Bullet for the same Shashank.A Motorbikes 3 13th April 2010 20:06
Preparing your car for a cross country off road trip tsk1979 4x4 Technical 16 18th July 2009 17:45
Maruti preparing for Tata's 1 Lakh car by planning to slash 800 prices by 60,000 rajdoll The Indian Car Scene 20 20th September 2006 23:12
