Old 20th July 2009, 11:09   #1
Shashank.A's Avatar
Default Leh Trip : Preparing a Carb car
I am planning to take my Carb Esteem 97 to Delhi-Manali-Leh-Srinagar-Jammu-Delhi trip. I am sure most of the team bhp members are aware about the terrain and conditions over there.
Considering the age of the car, I would like to take some advice on how to ensure that car performs to its optimum level at high altitudes, and to minimize the chances of stalling or getting stuck somewhere.
Shashank.A is offline   Reply With Quote
Old 20th July 2009, 11:26   #2
nitrous's Avatar
Thanked: 285 Times
Learn how and when to advance/retard ignition timing. Might help at higher altitudes.
Leave the fuel mixture as it is. At high altitudes, it will just run a bit richer which is good for the engine.
Old 20th July 2009, 11:30   #3
Sha
Sha's Avatar
Contact Swastikviji he has good knowledge how to configure carb, recently he completed 8000 KM in Carb Gypsy.
Sha is offline   Reply With Quote
Old 20th July 2009, 11:33   #4
Shashank.A's Avatar
Now this is something I seriously need to consider, I have come across this term quite a few times and have no idea what it means. I guess last time it was mentioned to me was when I was gathering knowledge on Bullet.
Old 20th July 2009, 14:32   #5
simply_sunny001's Avatar
Thanked: 15 Times
Carry a couple of air filters and like Nitrous mentioned you have to have the knowledge of advancing/retrarding the timing as Oxygen get low and Carb engines find it difficult to manage the climb.
Get your tyres/suspension and get some protection for underbelly like skid plates done.
Get everything checked, the esteem should be in a gr8 condition before you start the trip as i dont want to repeat what you did in Shimla/Kufri.
Rest i think you have to drive/negotiate the potholes/snow/slush carefully and you would be good to go.
cheers
simply_sunny001 is offline   Reply With Quote
Old 20th July 2009, 16:07   #6
Shashank.A's Avatar
Thanks Sunny Bhai.
After that I got a new clutch installed. I have also been told that if the car stalls on steep inclines that Choke is helpfull.
Regarding the timing, I guess I will get it done in Manali itself. Also GD told me to remove one of the pies from Carb and close it, it would good for higher altitudes.
What about Underbelly protection ? Where to get it done in Delhi and approx costing ?
Old 20th July 2009, 16:09   #7
suman's Avatar
Thanked: 257 Times
Lordofgondor just returned from a Leh trip in his Esteem - you could check with him.
Old 20th July 2009, 19:48   #8
Thanked: 54 Times
Go to the guys that build/repair buses and trucks - and ask them to make a sump guard for you with a thick sheet of aluminum(6mm - 8mm thick sheet should do the trick ).
techn0l0gist is offline   Reply With Quote
Old 21st July 2009, 11:02   #9
Thanked: 103,378 Times
Shashank, you might want to screen through this thread (Delhi To Leh - Possible on a Ford Ikon ?) too.
Old 21st July 2009, 11:43   #10
Shashank.A's Avatar
Thanks GTO, have gone through that thread earlier. The Picture of Tavera stuck in mud makes you thing twice. But thats the fun part, the unpredictability of it all.
here are two major factors in my mind, the Underbelly and Carburetor.
Old 21st July 2009, 12:33   #11
Thanked: 54 Times
get a proper sump guard done , and about the carb - well I don't think there should be anything much to worry about, learn to tune the carb if you already don't - and make it a little rich when you are up in the hills (well, might not be necessary too, as the AFR would become rich anyways as the altitude increases )
You might want to go to any of the guys that prepare cars for Raid De Himalaya and get your car checked - I don't think you would have anything to worry about then!
Old 21st July 2009, 14:28   #12
Shashank.A's Avatar
Seems like a good advice.
Does anyone know about someone who does this ?
Old 21st July 2009, 15:01   #13
nitrous's Avatar
Thanked: 285 Times
In the process of fabricating a sump guard, make sure you don't lose your ground clearance.
Old 25th July 2009, 11:45   #14
Shashank.A's Avatar
I talked to couple of modifiers y'day was quoted figures of 10K +, for Sump Guard and fuel tank guard. However have also been told that it can be done by people making bodies of trucks and buses for much lesser price.
Does anyone has nay experience with that ? I guess I need a body maker who has already done the job, because I have no idea of cars anatomy on the lower side.
Secondly, Just tried using the Choke, as have never used it since I have this car, and once I pulled the choke, the engine dies out. It did not start when choke is pulled on. However once I relase the choke, in the next self it sputters back to life. My Mechanic said he has to open the carb and change the Diaphram (I did not get what he was trying to say, I am assuming this is what he said).
And lastly, what is Dholki is in English, I know its the part ofthe exhaust pipe, but what is it called in english and what is exact function ?
Old 25th July 2009, 12:04   #15
phamilyman's Avatar
Thanked: 3,526 Times
ask gondor. he got it in 6500+ tax from Motorcraft!
Mission Leh! Four people, one scorpio and one helluva road trip! (Delhi-Leh Sep 2011) speed crusader Travelogues 15 11th July 2012 19:50
Ride to Leh - Preparing your Bullet for the same Shashank.A Motorbikes 3 13th April 2010 20:06
Preparing your car for a cross country off road trip tsk1979 4x4 Technical 16 18th July 2009 17:45
Maruti preparing for Tata's 1 Lakh car by planning to slash 800 prices by 60,000 rajdoll The Indian Car Scene 20 20th September 2006 23:12
