Old 21st July 2009, 18:05   #16
srijit's Avatar
Originally Posted by Technocrat View Post
Why would you need hot air during rains?
AC+Heater will work wonders
I normally use AC during rains to clear up the windscreen. However sometimes the mist refuses to go away. A few seconds of hot air blasting usually solves that.
Another incident in Kerala, where I found the heater useful.
It was a wet day and my pant legs were sodden. I drove nearly 100kms with the heated air flowing to the legs, and the windows partially open to reduce the heat buildup. It was wonderful.
srijit is offline   Reply With Quote
Old 22nd July 2009, 16:00   #17
Technocrat's Avatar
Thanked: 2,589 Times
So you are removing the mist on the other side this way
Old 22nd July 2009, 16:06   #18
SAHIR.KITTUR's Avatar
Thanked: 75 Times
Get it repaired at once, It will be a of great help when you plan to get LEH'd.
SAHIR.KITTUR is offline   Reply With Quote
Old 22nd July 2009, 16:06   #19
srijit's Avatar
Well, dont really care as long as it works.
Old 25th February 2014, 11:08   #20
rohan_iitr's Avatar
Thanked: 412 Times
Default Re: Heater Not Working - Does it matter
The AC heater in my i10 seems to be faulty.
I normally keep the AC temperature control knob in the center and keep the AC button always switched on while driving. I keep the blower at 1st position. I always use the AC in re-circulation mode.
When I used the car yesterday, the AC seemed to be cooling more than usual. I moved the AC temperature control knob to higher temperature, but there was no change in cooling. AC temperature seems to be stuck at the lowest temperature setting irrespective of the position of the control knob.
What could be the problem ?
The car is otherwise behaving normally. Engine temperature gauge is in the normal center position.
Coolant was changed in the last service, 7-8 months back.
Rohan
rohan_iitr is offline   Reply With Quote
Old 8th March 2014, 19:58   #21
rohan_iitr's Avatar
Thanked: 412 Times
Update : As suspected, the Hyundai A.S.S. had filled insufficient quantity of coolant during my previous service, when I asked for coolant change.
In the next service, I got the coolant topped up. Now the AC heater is also behaving normally.
Rohan
rohan_iitr is offline   (1) Thanks Reply With Quote
Modifications for Gypsy King - Does the sequence of modifications matter? khan_sultan Modifications & Accessories 18 6th September 2009 14:02
Speaker Size. Does it really matter? nitin.dangayach In-Car Entertainment 19 18th December 2008 17:15
Does Power really matter or Experience? sumitkalindi Street Experiences 16 7th November 2007 15:41
Does it matter what “we” think? adya33 The Indian Car Scene 19 13th December 2006 14:36
Does heater consume engine power? DCEite Technical Stuff 21 5th January 2006 00:28
