Old 26th August 2009, 10:01   #16
Nikhilb2008's Avatar
Thanked: 6,651 Times
Anand,
What I meant is even in normal cars running normal tyres, it is better you dont mix the right and left side of the tyres. If you do, then you will have pulling problems even if alignment is perfect. This is due to Road Force.
@ghostrider ---- There are so many other people who have Swift Ds which dont have the pulling problem. Why only a few people?
Anand, I did not take it as a complaint. Just that you had a problem which wasnt solved when you came to Madhus. That is why I was concerned. As I said, do give me a call for any assistance.
Old 20th October 2012, 15:06   #17
sdp1975's Avatar
Thanked: 972 Times
Default Re: Left drag - Swift 205/50/16 7J rim
Originally Posted by Nikhilb2008 View Post
Hunter themselves have a machine(a wheel balancer) called GSP 9700 Road Force Measurement. This basically has a roller which comes into contact with the tyre when it is rotating and then analyses the forces acting on it. The machine then advises the user where to fit the tyre.
Does this roller run at a fixed speed or a variable speed ?
I mean if I'm having a problem at speeds only between 35-40 kph would the machine catch it ?
sdp1975 is online now   Reply With Quote
Old 21st October 2012, 18:57   #18
Yes, it will catch it.
Nikhilb2008 is offline   (1) Thanks Reply With Quote
Swift + Yokohoma S drives 205/50 = What psi? inder_s1 Tyre & Alloy wheel Section 9 15th September 2008 19:14
WTB : Single 205/55/15 Tyre + 100 PCD 15" rim s0uljah Shifting gears 6 28th April 2008 11:52
Any Problem in putting Yoko 205 Tyres in Swift VDI? Rockzer Tyre & Alloy wheel Section 7 3rd March 2008 11:24
For Sale 15inch Swift Alloys with 205/55/15 Tires kumar_ranjan Shifting gears 9 25th January 2008 17:32
anyone using 205/45R17 for Swift?? sleepy Tyre & Alloy wheel Section 22 27th January 2007 16:28
