Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 21st July 2009, 03:56   #1 (permalink)
anandkumargb's Avatar
Default Left drag - Swift 205/50/16 7J rim
I noticed that after getting 205/50/16 7J rim with Yoko S - drives, my Swift VDI is dragging to left quite strongly.
I have visited Madhu's (on Langford road ) thrice and the problem persists. FYI Madhu's has the Hunter - Digital Imaging technology, apparently the best technology in Wheel allignment.
Also got wheels balanced 2 twice, all attempts futuile so far. However even after driving for 1000 Kms with this problem there is no uneven thread wear, just that the vehicle drags towards left. Tried & tested the car on all kinds of roads, super high ways, different speeds, accelerated thru gears; Problem exists!!!
Ok, forgot something, the tires are on nitrogen with 29 PSI front / 28 PSI rear.
Any suggestions??
__________________
Honesty is the best policy. There is much less competition!!
anandkumargb is offline   Reply With Quote
Old 21st July 2009, 11:58   #2 (permalink)
humyum's Avatar
Did u try rotating the tyres ? Try a tyre rotating from left to right and see if the problem gets sorted out.
__________________
Life is Simple - Eat,Drink,Swift!
Old 21st July 2009, 12:01   #3 (permalink)
karankapoor's Avatar
As humyum said try rotating all the tyres this will solve the problem, This solved mine give a try before doing something else.
__________________
P80RSII l ID Chameleon's l Genesis Dual Mono l ID Max l Genesis Dual Mono EXtreme l Kicker l Connection Audison l Dynamat
karankapoor is offline   Reply With Quote
Old 21st July 2009, 21:05   #4 (permalink)
I swaped the front wheels with the rear wheels, but did not rotate them from left to right since these are rotation/directional tires. I need to remove them from the alloys and then only change them. I have not tried that.
Just curious as to how should that matter? Since all wheels are balanced properly.
__________________
Old 21st July 2009, 22:36   #5 (permalink)
humyum's Avatar
Well i dont know, just a hunch, since the alignment seems right and the there was no pull before u got those new tyres, tyres can be the only culprit here.
__________________
Old 21st July 2009, 23:34   #6 (permalink)
gpa
gpa's Avatar
Do you mean uni-directional tyres?
__________________
Maruti Suzuki Alto (May 08) - 23,000 KMS
Hyundai Santro (Feb 05) - 59,000 KMS
Old 22nd July 2009, 00:22   #7 (permalink)
Nikhilb2008's Avatar
dude, give me a call.
Nikhilb2008 is online now   Reply With Quote
Old 22nd July 2009, 00:39   #8 (permalink)
kpzen's Avatar
Remove the left wheel, swap the tire inside out.
__________________
Prajesh
Old 22nd July 2009, 00:43   #9 (permalink)
kuttapan's Avatar
Any suggestions??
As others said, rotation can help, I used to notice this problem after a rotation was done. Usually this goes away after a few thousand kms, but then it is time for the next rotation.
kuttapan is offline   Reply With Quote
Old 22nd July 2009, 01:07   #10 (permalink)
This is due to something called Road Force.
There are machines to detect this. It can never be solved as such. Hunter themselves have a machine(a wheel balancer) called GSP 9700 Road Force Measurement. This basically has a roller which comes into contact with the tyre when it is rotating and then analyses the forces acting on it. The machine then advises the user where to fit the tyre.
You havent mentioned if you got wheel rotation done just before this problem started.
Also, this is why it is always recommended to do a rotation only front to back and not to mix the left and right side tyres.
PS: You came to our shop 3 times. Didnt any of the guys tell you to do the rotation? It is standard practice to do so. Usually, that is the first thing to be done once the alignment is checked and found to be ok.
Old 22nd July 2009, 01:36   #11 (permalink)
ghostrider's Avatar
This has nothing to do with Road Force, or misalignment or poor balancing.
It's an inherent bug with almost all Swift-Ds. Do a thread search and you'll find a bunch of people with the same problem.
My DDiS does, so does a friend's. On a level road, at 50/60 kph if I let go of the steering wheel I'll move one lane to the left within 15-20 seconds. This is normal. It doesn't cause uneven tyre wear, but just make sure you rotate your tyres every 2-3 months.
ghostrider is offline   Reply With Quote
Old 22nd July 2009, 20:13   #12 (permalink)
Yep, thats what I meant to write, but forgot the correct term.
__________________
Old 22nd July 2009, 20:28   #13 (permalink)
Hey Buddy! Where were you all this while? Thought I would meet you when I visited your place last 2 times.
I got the wheel rotated front to back (same side, no mixing so far) after I had this problem. This idea was suggested by the elderly gentleman with glasses in your place in the allignment section. He wanted to change the wheels: Front left to rear right; Front right to rear left. Since these are uni-directional tires ( S drives), he dropped the idea since it involed deflating and removing the tires from alloys and I was in a hurry.
So what you are saying is not to mix the left and right side tyres??
Now I have driven around 1000 Kms after the last visit to your place, the drag apparently seems to have reduced a bit; however still exists!!!
__________________
Old 22nd July 2009, 20:44   #14 (permalink)
yzfrj's Avatar
I
Any suggestions??
This is not the solution to the problem you are haiving.
I feel the tyre pressure is Low for VDi taking into consideration the size of the tyre.
You can try the solution kpzen suggested.
Again as kuttapan said sometimes it does happen.
I had the same thing in my zen for the first 500kms or so after service and tyre rotation / alignment / balancing.
Maybe it will go away on its own.
yzfrj is online now   Reply With Quote
Old 26th August 2009, 02:31   #15 (permalink)
I am a happy customer of Madhu's; I hope my post did not come across as a complaint for Madhu's. It is just a problem after getting the big wheels on my Swift and it apparently also seems to be a inherent problem with swifts.
BTW, the drag has reduced a lot automatically.
I really appreciate the customer service of Madhu's; One of the best!!!
@ to all T-bhpians - You would all be happy to know that Nikhil offers 30% discount on his services to all Team BHP members! You need to have a Tbhp sticker on your car, thats all :-)
__________________
Thread Tools
Swift + Yokohoma S drives 205/50 = What psi? inder_s1 Tyre & Alloy wheel Section 9 15th September 2008 20:14
WTB : Single 205/55/15 Tyre + 100 PCD 15" rim s0uljah Shifting gears 6 28th April 2008 12:52
Any Problem in putting Yoko 205 Tyres in Swift VDI? Rockzer Tyre & Alloy wheel Section 7 3rd March 2008 11:24
For Sale 15inch Swift Alloys with 205/55/15 Tires kumar_ranjan Shifting gears 9 25th January 2008 17:32
anyone using 205/45R17 for Swift?? sleepy Tyre & Alloy wheel Section 22 27th January 2007 16:28
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
