Old 22nd July 2009, 23:45   #16
The turning circle will be same when moving forward and backward. But sharper turns are only possible with rear axle steering/ multiple axle steering which can be observed in CRANES/ TIPPER TRUCKS.
Rear axle steering only can make a vehicle turn a tighter corner hence we use the "reverse and park method".
Sujith1100 is offline   Reply With Quote
Old 23rd July 2009, 11:48   #17
planet_rocker's Avatar
Thanked: 368 Times
@ Sujith / Shantanu - that is what i had in mind : fire truck with rear steering wheels. i guess the same thing works when you are reversing in any car FWD & RWD.
planet_rocker is offline   Reply With Quote
Old 23rd July 2009, 12:23   #18
Shan2nu's Avatar
Thanked: 89 Times
Im not talking about reverse parking or reverse steering here.
Consider any normal car with front wheel steering:
If this vehicle is kept at full steering lock and moved forward (in a circular motion) the turning circle caused by the wheels should be indentical to the ones made by the same car going in reverse.
http://www.drivingfast.net/images/te...iff_radius.gif
If the car in the above link moves backwards with the same steering angle, wont it create a circle of the same diameter as the one shown in the pic?
According to my uncle, the circle should be smaller in reverse, which i dont think is possible (unless it has some specially designed differential).
The turning radius of the OHC is 4.8mtrs, i dont think il get a lower figure if i try it in reverse.
Shan2nu
The Vehicle with the smallest turning radius in India mithun The Indian Car Scene 53 22nd July 2009 11:45
Shorter wheelbase but large turning radius...WHY? deepgautam_qa Technical Stuff 3 27th May 2009 13:32
Used Maruti800, premier padmini , premier 118ne ? sakharamcool Hatchbacks 8 27th May 2008 11:17
How to decrease the Turning radius(Any Possible Mods)?? greatDrive Modifications & Accessories 14 3rd July 2007 12:24
