Old 6th September 2010, 20:48   #16
johnruben's Avatar
Thanked: 73 Times
Thanks Guys, I have swapped them and it looks fine, both engines cranked perfect
johnruben is offline   Reply With Quote
Old 6th September 2010, 21:30   #17
dhanushs's Avatar
Thanked: 4,054 Times
Great. . Now you just have to check if the alternators are capable of charging the batteries satisfactorily.
Old 7th September 2010, 00:49   #18
johnruben's Avatar
Thanked: 73 Times
How do I check if its charging properly ?
Old 7th September 2010, 09:05   #19
Thanked: 92 Times
Your new battery might take a little longer to charge fully, but, 3AH don't make a difference anyway. All you need to check is that if the old M800 alternator is actually giving good amps at Idle. Nevertheless, it was a good decision to switch battery from a less run car to a frequently run car as your battery will be in optimum condition always.
JustCause is offline   Reply With Quote
How come Swift DDiS and Indica Vista have such soft clutch? DCEite Technical Stuff 26 17th August 2015 01:32
Why Dubai has 6 Veyrons... and other such riches rankoz350 The International Automotive Scene 201 30th April 2010 18:44
Autocop and such similar products are of limited use! Zappo The Indian Car Scene 21 20th February 2007 20:31
Which is better for daily street use: Engine Swaps or Turbocharging? Sideways Modifications & Accessories 68 9th August 2006 13:14
Do i have any other choice other than Indica turbo diesel ?? tanishq Hatchbacks 35 11th June 2006 17:44
